02-13-2016, 11:29 AM | #1 |
66 suburban 5.3 swap
I'm building a 66 suburban trying to put the 5.3 out of an 04 Chevy truck into it. I have the motor mounts figured out and I'm gathering up other parts for the swap. My question is and I know it has probably been asked a hundred times will the truck exhaust manifolds fit without doing anything to the frame or do I need to try and find Camaro manifolds or headers? I will only be lowering truck about 2-3 inches so ground clearance isn't an issue.
02-13-2016, 12:07 PM | #2 |
Re: 66 suburban 5.3 swap
From what i have read you can not use the factory truck manifolds without cutting/heating bending the frame. 1998-200? 2010 up camaro or trail blazer manifolds fit most swaps. Hooker makes swap manifolds that fit
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-13-2016, 08:39 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Tbss manifolds work best for our trucks if you want sto stay factory lsx.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-13-2016, 11:16 PM | #4 |
what are tbss manifolds ?
02-13-2016, 11:56 PM | #5 |
tbss=Trailblazer SS
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-14-2016, 01:11 PM | #6 |
A friend built a 66 Suburban with the 5.3 and he used the Trailblazer SS manifolds.
02-14-2016, 05:36 PM | #7 |
i have personally used tbss manifolds and the hooker manifolds. Both worked out very well.
02-14-2016, 08:34 PM | #8 |
Has anyone used the shorty hooker headers?
02-22-2016, 12:25 AM | #9 |
Started the install of the 5.3 into the 66 looks like the ac compressor is going to be a tight fit in the lower position . Will it clear or is there another route to take looking for some ideas thanks
02-22-2016, 12:30 PM | #10 |
best to use the high mount.
I used Docs Blocks and trimmed the frame rail a tad. I don't know if Docs Blocks are used any longer. actually here they are. http://www.acsource.com/hoseblockhor...oringtype.aspx
02-22-2016, 12:57 PM | #11 |
2010+ Camaro manifolds are da bomb....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-22-2016, 11:29 PM | #12 | |
https://www.holley.com/products/acce...y/parts/20-134 |
02-22-2016, 11:36 PM | #13 |
Thanks for all the replies I found a set of 2010 Camaro exhaust manifolds with the cats still on them locally. Tried them on and only had a small amount of clearance problem on motor mount nothing big. Decided to try and keep the ac compressor on the bottom for now and had to make a small notch on the frame. Tomorrow night maybe I can make the trans mount and get it all bolted in.
02-24-2016, 11:48 PM | #14 |
All right got motor and tranny in what are you guys using for a driveshaft. The orginal with the carry bearing or the driveshaft from the doner vehicle, I need all the help I can get here from someone who has done this before ,thanks.
