02-17-2016, 12:14 AM | #1 |
Modify 283 air cleaner base HELP!!
Building a sleeper high hp 350 to look like a factory bone stock 283 in my 1964.
Since I haven't purchased a air cleaner yet I'm Thinking of pulling the trigger on a original 1964 283 2 barrel air cleaner (eBay) and fab a carburetor hole that will fit my 5"1/8" quadrajet. Any suggestions on which base maybe able to work or has someone pulled this fab off?
1949 Chevrolet 5 window 1970 C10 CST swb, fleet side 1964 C10 swb, bbw 1968 Camaro coupe 1968 camaro convertible (cream puff) 1972 K10 swb 4wd SuperCheyenne |
02-17-2016, 01:59 AM | #2 |
Re: Modify 283 air cleaner base HELP!!
I machine a adapter out of brass to go from 5 1/8" to 4" + for the early 4 barrel air cleaners on top of my edelbrock. Or you can cut an weld.
02-17-2016, 02:59 AM | #3 | |
02-17-2016, 09:52 AM | #4 | |
Aweseome... You sells these adapters? I'll give summit a call
02-17-2016, 09:59 AM | #5 |
Found a adaptor and risers that look like they'll work even though they're plastic?! thanks Fellas
http://www.spectreperformance.com/ca...dapters-risers
02-17-2016, 11:49 AM | #6 | |
Moderator
What if you want to do the opposite? Use a newer carb (5-1/8" carb throat) and want to use an older air cleaner. I don't think those adapters will work.
02-17-2016, 04:39 PM | #7 |
You're exactly right, they won't work. Maybe have to go plan B and weld. thanks
02-17-2016, 05:55 PM | #8 |
Moderator
Well if you do, can I put in a order for one?
02-17-2016, 06:48 PM | #9 |
Here is an option if you want to buy one pre-made:
Air cleaner assembly with 5" base They also sell just the base if you already have a lid: 5" base with 1" vent And they also offer bases with various size carb openings with & without the vent tubes. Here is the complete listing --> http://www.dr409.com/02_Engine_Ext_1.html (scroll down to the "Air Cleaners, Small Block Reproduction" and "Air Cleaner Parts" sections) |
02-17-2016, 09:07 PM | #10 |
Moderator
Would that 5" base fit a Edelbrock Carb?
02-17-2016, 09:18 PM | #11 |
Show Cars says on their site that the 5" air cleaners are for use with "aftermarket AFB" carburetors ... which is basically what the Edelbrock carbs are.
I believe they're simply rounding off the measurement to 5" even though the Edelbrock & Q-Jet carbs are actually 5-1/8". Similarly, they list the air cleaners that fit the stock Rochester 4gc carbs as 4" even though those are actually something like 4-7/32". |
02-17-2016, 10:50 PM | #12 |
Senior Enthusiast
Another solution might be to simply use a base from a filter that fits, and drop the early air cleaner lid over the top and tighten it down.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-18-2016, 12:52 AM | #13 | |
AWESOME
I may just buy a cheap mr gasket 14" and see if the base will work, thanks
02-26-2016, 10:54 AM | #14 | |
02-26-2016, 10:55 AM | #15 |
Bottom mount
08-14-2023, 08:32 PM | #16 |
08-14-2023, 10:33 PM | #17 |
If you have some welding skills, just cut the center out of the 2 barrel base, bend up some sheet metal to the height and diameter you need, then weld it up. That's what we did with mine when I went to a Quadrajet. I did have to make it tall enough to clear the HEI dizzy
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-14-2023, 10:46 PM | #18 | |
Ya was hoping not to have to cut my 2 bl base up but might have to if i cant find a 4bl base that will work
08-14-2023, 11:11 PM | #19 |
Looks like the link Ray posted a couple years ago is no longer active, but I did find this from I believe the same place. Maybe this could work for you? https://show-cars.com/product/1952
They also have a lot of other air cleaner stuff available: https://show-cars.com/02-engine-external
08-15-2023, 08:40 AM | #20 |
This is basically what I did, 2 barrel original on a i think 10" cheap china aircleaner bottom and a K&n filter sloped out to the original. A little shaping the bottom half and works great on a quadrajet
08-15-2023, 09:28 AM | #21 |
Pretty much what I did. Had the cheap open filter base and put my stock base over it and was happy it worked. This thread is pretty old so I am sure they solved their problem already.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-25-2023, 09:10 AM | #22 | |
I used a squarebody era 4bbl Q-jet GM truck air cleaner base & made it work by trimming/cutting the vertical portion off the base plate of the air cleaner housing.
09-08-2023, 08:06 AM | #23 |
I ended up using a base from an older 4 barrel gm air cleaner and got a spacer from the junkyard for a newer quadrajet . Cut/weld in place
09-08-2023, 09:12 AM | #24 |
Looks functional so goal accomplished.
