Old 02-18-2016, 11:14 PM   #1
Tony S.
64 c10 Power steering
Okay guy's, whats it gonna take here to install some power steering in my 64 c 10?
I'm installing a BB 454 along with a TH400 all from a 1978 c 20. I'm going to have the shifte(Lokar) on the floor.
Now I know I need a pump and lines and all that but what else do I need to get it done?
Thanks for the help all!
Tony S. is offline   Reply With Quote
Old 02-19-2016, 12:30 AM   #2
Captainfab
60-66 Nut
Re: 64 c10 Power steering
You will need the pump brackets for your particular engine and water pump configuration as well as the pulleys to drive it. Then you will need a '68-'86 C series or '87-'91 R series steering box and pitman arm. If you are also upgrading to disc brakes, I would recommend the entire steering linkage from your donor truck. And of course you will need a steering box adapter plate, hopefully from me. If you are keeping the original steering column you might need the tube and flange also.
Old 02-19-2016, 12:45 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Highly recommend CaptainFabs bracket. Works great!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-20-2016, 12:42 AM   #4
Tony S.
Thanks guy's! I really appreciate it! Gotta get some pics up here but only have truck without motor/tranny/interior... But as soon as I have something to show I will! Thanks again!!
power steering conversion, steering column mod
