Old 02-29-2016, 10:01 PM   #1
tlman
700r4 pains
ok guys help me! I think im using a 73 plus rear cross member it worked with the th350 ,now I am hitting the floor with top of 700 ,headers are pointing down,hmmm on an angle ,ive reworked the cross member and have it away from the floor ,but headers still point down slightly ,this truck has been apart totally ,only thing I can think of is that I have to shim cab up to raise the trans and lift headers up ,this is a complete resto ,original engine mounts but like I said ive reworked rear and still near floor and collectors on slight angle
Any ideas trans oil pan visually is lined up with frame rail ???????
tlman is offline   Reply With Quote
Old 02-29-2016, 10:04 PM   #2
jeh
jeh's Avatar
Re: 700r4 pains
Pics of the headers???
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 02-29-2016, 10:13 PM   #3
tlman
Re: 700r4 pains
gotta get one yet
the heagers are from 1978 k15 4x4
Old 02-29-2016, 10:33 PM   #4
Possmguts
Possmguts's Avatar
Re: 700r4 pains
The 700r4 is a bigger body trans than the TH350 was... If you have a short hump in the floor you may need to get a high hump... and then change carpet, ect, ect...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 02-29-2016, 10:41 PM   #5
tlman
Re: 700r4 pains
think im just gonna make exhaust fit now that i look at pipes that were attached ti these headers in 78 dont think i want to cut into new floor
Old 02-29-2016, 10:59 PM   #6
Possmguts
Possmguts's Avatar
Re: 700r4 pains
You have drive line angles to think about... if the motor and trans are at too much of an angle, youre gonna have issues...
Old 02-29-2016, 11:00 PM   #7
jeh
jeh's Avatar
Re: 700r4 pains
I "had" a 700r4 in my truck with a BB and a low hump floor and didn't have any problems. I built my own transmission crossmember after I got the engine and transmission where I wanted it, but I did have enough room under the cab. The reason I wanted to see a pic of the headers is to see if they turned down somewhat, if that's the case they won't be parallel with the frame.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 02-29-2016, 11:06 PM   #8
tlman
Re: 700r4 pains
the more.i.look at it all angles are fine the pipes and headers im using off other truck that i put big block in match in angles as they were in it just need to twk them to fit this chassis, this is a complete new build so ive been adjusting all the way, cant wait toput fronf clip and box. on
Old 03-01-2016, 08:25 AM   #9
iostorm
Re: 700r4 pains
That paint looks like Indian Motorcycle Red, what color is it?
iostorm is offline   Reply With Quote
Old 03-01-2016, 08:28 AM   #10
tlman
Re: 700r4 pains
I roughly told my body guy what colour I wanted ,this is what he come upwith ,I don't know but I like it and the exterior will be same but more metallic ,im trying to figure out how to get all my pics on here
Old 03-01-2016, 11:57 AM   #11
snipescastle2
snipescastle2's Avatar
Talking Re: 700r4 pains
I put a 700 R4 in my shortbed, didn't have any weird angles to deal with at all.using stock small block mounts and perches, even used a stock 700R4 tranws mount too.my truck originally had a long tail shaft 350 turbo in it, (with the factory cross member) I did have to shorten the drive shaft though. Was your truck an automatic or stick? Just wondering if the cross member might be different or the mount....
Ben
snipescastle2 is offline   Reply With Quote
Old 03-01-2016, 12:23 PM   #12
tlman
Re: 700r4 pains
ya all different it was 3 spd ,cut that cross out last weekend and then figured out 30 yrs ago I put 73 rear cross in and that worked with th350 but not 700 all angles are good just my headers different angle but can accommodate them ,I reworked 73 cross member and it all sits well ,now just gotta crry on ,it was supposed to be a stress reliever , now its turned into obsession .
I built one of these in early 80s ,a 1967 gmc ,looked exactly the same but stayed with 3 spd and modified complete front hood tilt
Old 03-01-2016, 01:27 PM   #13
snipescastle2
Tilt front end huh? Man, that must have been some undertaking to get done! I thought a complete cab rear brace was an accomplishment!!! Wow!
Ben
Old 03-01-2016, 01:31 PM   #14
tlman
Re: 700r4 pains
ill find a picture and post it i look way younger in 1981 when i did this one, shows hood open
Old 03-01-2016, 02:49 PM   #15
tlman
Re: 700r4 pains
1981
Old 03-01-2016, 03:27 PM   #16
snipescastle2
that's cool! definitely different!
Ben
Old 03-01-2016, 03:31 PM   #17
tlman
Re: 700r4 pains
ya skil saw and brazing rod all we had on farm lol
Old 03-01-2016, 11:34 PM   #18
Possmguts
Possmguts's Avatar
Re: 700r4 pains
Now Thats something you dont see every day... Love the big truck hood latches
Old 03-01-2016, 11:43 PM   #19
tlman
Re: 700r4 pains
i have enough extra parts to build tilt hood again and put regular front clip on for now and take my time building new
Old 03-02-2016, 10:44 AM   #20
snipescastle2
Today you can find linear actuators that will open it for you, just an idea.....
Ben
Old 03-02-2016, 10:50 AM   #21
tlman
Re: 700r4 pains
oh for sure and wow a mig welder instead of braze welding and warping, plasma,things have changed ,I own heavy truck equipment repair shop so its a little easier now and have a good supply of ideas from big trucks to carry on with current build ,and now it seemed to turn into an obsession with this truck lol the tiger stripe 1978 I built 7 yrs ago same way start in april and on rd by sept complete frame off
Old 03-02-2016, 12:20 PM   #22
snipescastle2
I've been plugging away at my build since July 2013....and mine was purchased as a "Basket Case" I bought it from a guy who started the project, he completely disassembled it, bought a
'70 parts truck and got a bunch of new patch panels and lots of parts to boot.
After I got the rockers and cab corners done on that cab, I couldn't get to doors to align, even with a porta-power.....ended up getting a '72 cab.
Turns out, the original chassis had a crappy repair done to it, had angle iron welded to the frame rail, bird crap welds,etc....couldn't use that chassis, but the P.O. I bought it from knew that and gave me a straight 67 SWB chassis.
Apparently, somebody rear ended another vehicle, the truck got rear ended, pushed the
Bed into the cab and distorted it pretty badly.
I've come a long ways and almost ready to fire it for the first time.....yeah!
Ben
Old 03-02-2016, 08:29 PM   #23
tlman
Re: 700r4 pains
my frame slightly twisted at front ,straightened it many yrs ago and ive measured it a lot of times to make sure but all is going together well
