Old 03-01-2016, 01:03 PM   #1
Lefkada
'72 C20 brought home to California
I figured it was time to catch up on my build progress.
I brought this original CA truck back home to Southern California in December. Overall, very little rust aside from rocker panels, sidewall of foot wells and lower support of fleetside cargo. Very poor paint job done over original medium olive paint. Original 350/350.
PO installed Edelbrock carb and electric fuel pump (mounted to inside of front bumper (!?) with dangling power wire feeding back to fuse box and shoved into currently used circuit). According to PO, the previous previous owner rebuilt motor at some point and tranny had been rebuilt 2,000 miles ago.
Overall, the wiring is so macgyvered throughout the truck, I'm surprised there wasn't a catastrophic event.
1972 C/20 LWB, 350/350
Lefkada is offline   Reply With Quote
Old 03-01-2016, 01:13 PM   #2
Lefkada
Re: '72 C20 brought home to California
Truck is home and I begin tearing out interior for inspection.
Originally came with Aux tank option but aux tank was removed from bed at some point.
PO also installed Hedman headers recently it seems. A/C does not work due to missing condenser, but heater works.
All cluster gauges seem to work except for temp gauge. PO has installed an aftermarket temp gauge underneath dash, as well as choke.
The white wire shown in Fuse box photo is the previously mentioned electric fuel pump power wire.
Typical rubber hose + plastic fuel filter.
Old 03-01-2016, 01:25 PM   #3
Lefkada
Begin tear down. There is a small leak from rear diff and tranny (speedo cable).
Whoever rebuilt the motor used a grab bag of bolts to put the thing back together, complete with stacking 5-6 washers (or a nut) at some spots to compensate for having too long of bolts. Yikes.
Old 03-01-2016, 01:33 PM   #4
Lefkada
Removing motor and frame is off to the sandblaster.
Also cut rusted-out rocker panels from cab.
Old 03-01-2016, 01:42 PM   #5
Lefkada
Back from blaster!
Prime and paint frame.
Old 03-01-2016, 01:50 PM   #6
Lefkada
Took in original heads for valve job and resurfacing. Unfortunately, both heads were found to have hairline fractures upon magnaflux. Purchased an extra set of SBC heads that machine shop had on hand (and tested).
Begin rebuilding motor and remounting on frame. All body parts are currently at blaster.
Old 03-02-2016, 03:48 AM   #7
El Dorado Jim
looking good!
El Dorado Jim is offline   Reply With Quote
Old 03-02-2016, 12:40 PM   #8
Lefkada
Thanks, Jim!
New repro passenger-side fender has arrived to replace original, as well as 33" tires.
Will be picking up these wheels used off of Craigslist later today.
Old 03-05-2016, 01:25 AM   #9
Lefkada
Picked up everything from the sandblaster today. Cab, bed, doors, and hood went to the paint shop to be primered ASAP (it may actually rain in Southern California this weekend?!) and the full bottom rhino-lined.
Brought the headers home to coat and install.
Old 03-06-2016, 08:10 PM   #10
AKC
AKC's Avatar
Looks good, I'll be watching...
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline   Reply With Quote
Old 03-07-2016, 01:59 PM   #11
bs46488
Wow, you don't joke around with your projects. Making me feel a little lazy here.
What part of San Diego? I'm in the East County.
bs46488 is offline   Reply With Quote
Old 03-07-2016, 07:57 PM   #12
Lefkada
You know how it is!
I'm in Encinitas. Have you been getting any of this much needed rain down there?
Old 03-07-2016, 08:05 PM   #13
Lefkada
Wheels have been mounted on new tires. New lug nuts have been ordered from Amazon, but I'm still looking around for some good-looking center caps. Any suggestions?
Drive shaft, front and rear shocks (plus new front coils that I forgot to mention), and mufflers/pipes have been installed. I should have sanded and painted the drive shaft beforehand, but I was getting antsy.
