![]() ![]() Join Date: Jul 2002
I'm putting a Blazer fuel tank in my truck to replace the stock one. Do I need an in-line or extra fuel pump for it or will the stock mechanical fuel pump work OK for me?
I've seem a few pictures of others doing it on the board and they all seemed to have additional or the electric HiPerf fuel pumps. My engine is stock (all 250 cubes of it ![]() Thanks
My relocated tank isn't from a blazer, but my stock fuel pump has worked fine with it for more than 5 years... don't try to fix something that ain't broke yet...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
![]() Join Date: Jul 2003
Your pump will be fine.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
It will be the same as a six cylinder Blazer. You won't have any problems.
Are you using the Blazer hard lines or did you find a better way of getting your fuel from rear to the front? This has nothing to do with your fuel pump, I'm just curious.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
I haven't run the lines yet. Not sure if I'm going to use blazer/burb style (V8 size) stock lines. I've been looking at some marine style fuel lines.
I have the GMC Paul's 21 gallon re-lo kit/tank and it works fine with the stock pump. Because mine was done when I bought the truck I didn't get a chance to choose where the filler went. The previous owner did an ok job but this pic borrowed from Tennesen is the best way I've seen yet to do the filler!
Alex 1971 Lil' Red 350 SBC 700R4 |
Palf70Step, I was just asking to see if you already had the fuel lines run. I have seen some post here and have heard to use the Blazer fuel lines to make an easier run to the fuel pump. I used the braided stainless steel lines and it was more expensive than I thought and not as easy. I had a good reason why I did it, but if I were going to do it again on another truck I would have used the blazer fuel lines. Keep us informed on what you end up installing...
Chaptr2
Resident Curmudgeon
![]() Join Date: Dec 1999
They made burbs mechanical fuel pumps with no problems with fuels delivery and this is on a 127 inch wheelbase platform.
When I installed new tank and ran lines on my burb, I used 3/8 hard lines along the frame rail. These are the same hard lines used for brake lines, with same couplings. No problem whatsoever. I think all blazer/burb repo sending units are 3/8 lines, so if it were me I'd run 3/8 all the way to the fuel pump. If you do go with a 4bbl v8, you won't have to redo your fuel lines too.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
