03-17-2016, 05:07 PM | #1 |
Parting - 1972 4WD Blazer
Pulling the suspension in "Mid June". I will pull the drivetrain earlier if a can have most of it sold.
I am posting this thread in advance because once I pull the Blazer in the garage to begin the conversion I do not have much room to store the parts I pull and need them gone. I am going to be replacing the 4WD suspension and drivetrain with 2WD, 5 Lug, LS powered and vintage air. I will be selling all the 4WD suspension, drivetrain, wheels and tires and A/C system. Last edited by Frugalmeyer; 03-17-2016 at 11:47 PM. |
03-17-2016, 05:08 PM | #2 |
Re: Parting - 1972 4WD Blazer
I will be keeping the A/C control and dash vents.
03-17-2016, 06:37 PM | #3 |
Interest in the evaporator mounted in front of the radiator. What shape is it in??? Any broken fins??
03-17-2016, 07:04 PM | #4 |
I need vac canister, inside and outside vac actuators, all brackets for actuators, also flapper in cowl.there is a couple of rods that hook to actuators l need.how much to 89015..thanks
03-17-2016, 07:21 PM | #5 |
What gear ratio are the axles?
03-17-2016, 09:00 PM | #6 |
Looks like RAZ axle code but not sure. Photos attached.
03-17-2016, 09:25 PM | #7 |
How much
03-17-2016, 10:55 PM | #8 |
Does it have a skid plate and cross member for the transfer case? Also how about the gear reducer for the speedometer cable. Would need them shipped to 84043.
Thanks, Paul |
03-18-2016, 12:05 AM | #9 |
Transfer cross member and skid plate.
03-18-2016, 01:52 AM | #10 |
Interested in the cowl vent flap assembly. Stick or auto? Looking for single bend shifter if stick.
Thanks |
03-18-2016, 05:23 AM | #11 |
Possibly interested in all of the AC components mounted to the inside and outside of the firewall plus the compressor, brackets hoses, and other bric-a-brac that you aren't keeping. I don't need the condenser, controls, diverter box or dashboard stuff.
03-18-2016, 05:40 AM | #12 |
Carpe manana
I'd be interested in the following pending condition pics and cost w shipping to 87107:
Radiator Fan shroud Fuel tank skid plate w attach bolts Linkage from shift lever to tcase and or tcase shifter bolt Hei distributor Engine oil dip stick Metal hose strap affixed to inner RH fender w screws Thanks
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 03-18-2016 at 05:43 AM. Reason: Added |
03-18-2016, 11:58 AM | #13 |
I would be interested in a bed mat if its a clean one or even has it
thanks |
03-18-2016, 08:45 PM | #14 |
Is the 4x4 shifter Chrome if so what condition and price?
03-18-2016, 09:18 PM | #15 |
No Bed mat.
03-19-2016, 03:42 PM | #16 |
Interested in
front leaf spring hanger brackets bump stop brackets upper shock brackets rear spring front brackets radiator core brackets |
03-19-2016, 04:52 PM | #17 |
Please put me in line for the AC vacuum ball tank and bracket. Shipping would be to 40353. Thanks
Michael |
03-20-2016, 05:18 PM | #18 |
Moderator
Please list prices per forum rules ASAP. Thank you!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-20-2016, 09:20 PM | #19 |
I am new to this board and will read the rules and try this again. Sorry for any inconvenience.
03-21-2016, 02:00 AM | #20 |
interested in drive shaft.
03-21-2016, 10:56 AM | #21 |
are you selling the hatch
03-21-2016, 08:26 PM | #22 |
I'm giving up first dibs on the AC equipment to any of you guys who may have an immediate need. If no one needs them then I may be baaaack....
03-21-2016, 08:50 PM | #23 |
Radiator 85.00 plus shipping. No leaks.
Fan Shroud 55.00 plus shipping. One hole drilled in center top. DeadheadNM has first dibs. |
03-21-2016, 09:08 PM | #24 |
Carpe manana
Thank you - I'll take the radiator pending ship cost to 87107 if it's a 4-row Harrison for auto tranny K5. I'll pass on the shroud but would be interested in the clips that mount the lower shroud to the rad support if present and curious about remaining items on the list. Best, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-21-2016, 10:31 PM | #25 |
DeadheadNM
Looks like a 3 row factory radiator. Clips will go with the fan shroud. |
