Old 03-23-2016, 10:23 AM   #1
aod92
aod92's Avatar
Oil pressure too high??
I started my truck for the first time last week. The oil pressure climbed past 100 psi. This is on an autometer electric gauge. I'm gonna hook up a mechanical gauge to make sure the reading is correct. When I put the new pump in the motor I used a Melling pump. It came with two springs. I believe one was red and the other was blue. The red one is in the pump. Could the high pressure oil pump really be making this much pressure? I'm sure with it making that much pressure it can't be good.
aod92 is offline   Reply With Quote
Old 03-23-2016, 01:04 PM   #2
akdg87
akdg87's Avatar
Re: Oil pressure too high??
could be a bad relief valve on the oil pump or an incorrectly manufactured oil filter. but first verify with a mechanical gauge.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 03-23-2016, 01:52 PM   #3
indymachinist
No, the Melling pump should not make that much pressure at idle. Even with the high pressure spring that is unreasonable.
Like you said, start by checking the gauge. We can go from there.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 03-24-2016, 12:38 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are you running the 10295 or the 10296? If your running a higher-volume pump, with the high pressure spring, on a tight motor (meaning new bearings etc, minimal leak-by), then I can see you getting 100-ish psi on cold break in oil.
Did the psi drop after the oil warmup up at all? Melling's "high" spring is around 75psi.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-24-2016, 05:10 AM   #5
aod92
aod92's Avatar
I'm running the 10295 with the red spring. The motor isn't a new motor though. Prob about 80k on the short block. I didn't let it run very long because I was worried about the pressure. So it didn't even warm up.
Old 03-24-2016, 05:01 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The 10295 is the standard volume pump, so there's no reason it should be that high on a used engine. Even with the high spring that seems excessive. Its possible that relief valve is stuck.
Old 03-24-2016, 05:13 PM   #7
aod92
aod92's Avatar
I'm Hoping it's just the gauge. I'm gonna run to the parts store tomorrow and buy a mechanical gauge. Fingers crossed! You guys ever try dropping the pan on one of our trucks with the motor still in the truck?
Old 03-26-2016, 04:50 PM   #8
aod92
aod92's Avatar
I feel much better now knowing I don't have to drop my pan! Hooked up a mechanical gauge and its reading between 50-60 pounds. Thanks for the help guys!
Old 03-27-2016, 11:46 AM   #9
aod92
aod92's Avatar
Here's a vid of it running!
http://s1092.photobucket.com/user/ao...C28C3.mp4.html
