Old 03-26-2016, 12:38 AM   #1
lowrodderchev
lowrodderchev's Avatar
2001 LS pedal
times coming close to put this bad boy in. but I still haven't figured out my pedal. is there any certain year of pedal I need? or can I run any year of pedal for my 2001 LS 5.3 thank you
Name:  WP_20160323_004 - Copy.jpg
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 03-26-2016, 12:53 AM   #2
izzy_Britton
izzy_Britton's Avatar
Re: 2001 LS pedal
I like the paint job. been considering painting mine up too.
As for your pedal, I cannot answer since i am not familiar with the 57 chevy trucks. but if i had to guess, assuming your planning to do drive by cable, you could use the gas pedal out of any 70/71 or newer truck and make a mount plate for it and use the cable from the donor vehicle or even a 98-02 camaro?
just a guess. I honestly dont know.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 03-26-2016, 01:13 AM   #3
lowrodderchev
Re: 2001 LS pedal
Oh no its not for my 57 its for my 75 Chevy k5
Old 03-26-2016, 01:17 AM   #4
izzy_Britton
Re: 2001 LS pedal
well in that case! use your stock pedal, and slap a cable from a camaro or van or shorten the 99-15 cable. I have been under the impression that the VAN cable is the shorter one and requires no modification. but again, i am working on my 86 (virtually the same as your 75, and i have not gotten to this point yet.
Old 03-26-2016, 02:08 AM   #5
lowrodderchev
Re: 2001 LS pedal
Ok so I have a throttle cable, and another cable that goes to a box that I'm assuming is for cruise control? Correct
Old 03-26-2016, 02:15 AM   #6
izzy_Britton
Re: 2001 LS pedal
IF it looks something like this then yeah, its a cruise control module/box/servo/whathaveya
for info on that, check this: http://67-72chevytrucks.com/vboard/s...d.php?t=511477
Old 03-29-2016, 11:52 PM   #7
lowrodderchev
Re: 2001 LS pedal
Can anyone tell me were this line goes to?
Old 03-30-2016, 12:40 AM   #8
izzy_Britton
Re: 2001 LS pedal
hard to tell what your holding exactly in the photo. but appears to be an aux. vacuum port. block it or use it for whatever you want.
Old 03-30-2016, 11:59 AM   #9
foamypirate
foamypirate's Avatar
Re: 2001 LS pedal
Attachment 1516515
If you have a return style fuel rail, I think that goes to the pressure regulator.
foamypirate is offline   Reply With Quote
Old 03-30-2016, 12:14 PM   #10
lowrodderchev
Re: 2001 LS pedal
Its on the passenger side.I have the return line pressure hooked up on the drivers side thinking I can hook up my heater vacuum there
Old 03-30-2016, 12:25 PM   #11
lowrodderchev
Re: 2001 LS pedal
Here's a few better pix
Old 03-30-2016, 12:52 PM   #12
foamypirate
Re: 2001 LS pedal
Yep, that will work great for your climate control vacuum source in that case.
Old 03-30-2016, 01:15 PM   #13
izzy_Britton
Re: 2001 LS pedal
I think the pressure regulator is on the other side? The picture is from the rear looking forward. On 2 of my 3 manifolds that port is blocked off, one manifold doesn't even have a nipple there.
Old 03-30-2016, 01:18 PM   #14
izzy_Britton
Re: 2001 LS pedal
Oops! I guess this was already addressed in the time it took me to compose a reply. Sorry
ShouldNotDriveAndSurfChevyForumsIzzy
Old 03-30-2016, 01:40 PM   #15
lowrodderchev
Re: 2001 LS pedal
No its cool I appreciate all the help I can get but am I right I can use that for my heater vacuum.port
Old 03-30-2016, 01:41 PM   #16
izzy_Britton
Re: 2001 LS pedal
Yes, you can use it for heater vacuum port.
Old 04-01-2016, 07:11 PM   #17
lowrodderchev
Re: 2001 LS pedal
Another questions guys, are these the correct adapters for my fuel rails?
Old 04-01-2016, 07:13 PM   #18
lowrodderchev
Re: 2001 LS pedal
Also can I just run a braided line from my sending unit to metal lines on the frame? Does anybody know the thread size? Thank you
Old 04-01-2016, 09:23 PM   #19
truckdude239
truckdude239's Avatar
Re: 2001 LS pedal
I cut the ends off my sender and used an compression fit5ing
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-01-2016, 09:31 PM   #20
lowrodderchev
Re: 2001 LS pedal
do you have any pix of what you did?
Old 04-01-2016, 11:01 PM   #21
foamypirate
Re: 2001 LS pedal
The fittings on your sending unit are metric o-ring, I believe M14x1.5 and M16x1.5, if I recall correctly. You can get adapters to convert to AN. Don't cut them off for compression fittings, that's a downgrade since you already have threaded fittings.
Also, those fittings you have listed above are correct. One 3/8 for the fuel supply, one 5/16 for the fuel return. Braided stainless line for the whole length will work, but I would use braided stainless hose to jump to a hard line down the frame, and then back to a braided line from the front of the hard line to the engine. That's just me though, since I tend to have tubing on hand and have all the fittings, unions, and bending tools to do it.
If you do go for full length braided hose, make sure it is PTFE lined! A lot of the AN hose on the market is not very compatible with ethanol fuel and can get soft over time. The PTFE lined hose does not have this problem, but you have to use specific fittings and "olives" with it. Make sure you get it all from one manufacturer.
Old 04-02-2016, 09:11 PM   #22
izzy_Britton
Re: 2001 LS pedal
Attachment 1517233
What fuel pump is this and what are you installing it in?
Old 04-02-2016, 11:13 PM   #23
lowrodderchev
Re: 2001 LS pedal
sorry forgot about the details. 87 blazer tank with a 87 sending unit
