Old 03-27-2016, 12:15 PM   #1
roundhouse
Fuel lines ?
alright,
have the old 350 out of our '76 K-10 and am looking for fuel line advice.
we have been ruing the tank from a 1987 as we were running TBI,
so we plan to swap the EP381 pump into the tank,
then what?
the fittings on our sending unit are barbed for a slip on rubber hose.
do we need to have a shop weld on 6AN threaded fittings?
Ive used the rubber EFI hose and barbed fittings with 2 EFI clamps on the lines on my 74 Bronco with a 1990 mustang 5.0 EFI for almost 15 years with no issues and I think it has only slightly lower pressure.
and what are yall using for the supply and return lines?
engine is a 2001 drive by cable with a supply and a return line on the rail
I assume the TBI return line we be ok to use since its no pressure?
anyone using this supply line?
http://www.summitracing.com/parts/su...commendedparts
any tips on installing the fittings on the ends?
roundhouse is offline   Reply With Quote
Old 03-27-2016, 11:15 PM   #2
Robznob11
Robznob11's Avatar
Re: Fuel lines ?
Originally Posted by roundhouse View Post
alright,
then what?
I run that efi specific rubber hose with the efi specific clamps. And the Dorman replacement efi metal ends. I run a racetronix 255 lph pump that puts out 65 psi and no problems! I run 3/8 metal lines on the frame and I used a double flare tool and inverted flare fittings to go from metal to rubber.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-29-2016, 10:36 AM   #3
roundhouse
Re: Fuel lines ?
The efi replacemt ends are just barb fittings ?
Old 03-29-2016, 10:47 AM   #4
Robznob11
Robznob11's Avatar
Re: Fuel lines ?
Pt# 800-121
LED TAILS
