Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-30-2016, 08:20 PM   #1
rkn463
rkn463's Avatar
Replace steering box seals
I have an 89 c60 that has a Saginaw 710 power steering box. The input shaft seals are leaking. I have a factory shop manual and it has instructions for how to replace the seal for the pitman arm but nothing for the input shaft. It looks like a seal kit is available but I've never worked on a steering box before and I don't know if it is something that I can do myself. Does anyone out there have any experience with this or a manual with instructions?
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 04-02-2016, 12:38 AM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: Replace steering box seals
It's not a tough job, the main thing you need to pay attention to is the position of the bearing lock and adjustment nuts. You need to count the number of turns it takes to remove both of them. I use a hammer and chisel to stake a mark on the box housing and both nuts before I remove them just to make sure they line up in the same position as they were. You can remove the lock nut with a hammer and drift punch, it will be on there fairly tight. The actual adjustment nut is made to be installed/removed with a pin type spanner wrench, but if you're careful not to chew up the threads you can use a pair of Channel-locks. My Grandpa and Dad showed me how to do that years ago, I've done several of them and never had a problem.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 04-02-2016, 09:23 AM   #3
rkn463
rkn463's Avatar
Sounds like just what I needed to know, thank you very much for the advice!
-Richard
