Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-01-2016, 03:19 PM   #1
Valarius_Starchaser
Valarius_Starchaser's Avatar
Big block Chevy build
I have been reading as many threads as I can on this subject all over the web but I wanted to throw some numbers out before I start the plunge this weekend for final assembly.
I have done small block bottom ends but never anything far from stock or a big block for that matter (well its about time )
What I have:
1974 BBC bored .30 over
Forged Rods - http://www.summitracing.com/parts/SCA-26135
Forged pistons - http://www.summitracing.com/parts/PBP-P4963F-030
stock crank .020 over and balanced
Piston rings - http://www.summitracing.com/parts/slp-r9590035
The end goal is to have a shot of NOS so keep that in mind as well
Now to my questions I have been reading up on recommended crank end play and connecting rod side clearance and am finding tons of mixed reviews on the subject and at the same time all of them are for small blocks is this information usable for my big block or do I need to follow a separate set of rules on this?
Top ring gap of .022
Bottom ring gap of .025
Bearing clearance of .0020-.0025
Rod side clearance between .004-.025 I'm seeing is called "okay" I'm really wondering on this number though
Crank end play on an application like mine of no less then .006 but I cannot find how much is to much on this I obviously don't want my crank walking around
Hopefully someone with experience on this can help me out here before I have a heart attack or go insane from reading so many articles and threads with conflicting views.
-Logan
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-02-2016, 09:42 PM   #2
Blue Rat
Re: Big block Chevy build
Around .002-.010 is good.
Blue Rat is offline   Reply With Quote
Old 04-08-2016, 01:42 PM   #3
Valarius_Starchaser
Thanks for the input didn't see it until today when I came back to delete the thread due to no responses I ended up at .003 and was told that was fine by a local machine shop so I suppose it should all work out fine if anyone from this section is interested I posted up the progress pics in my build thread starting at post #100
"Orange Crush"
Old 04-08-2016, 09:21 PM   #4
CST10
CST10's Avatar
Keep the post going. Supply details on the build. I'm interested how the build goes. I'm thinking of building one myself.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 04-08-2016, 10:34 PM   #5
Valarius_Starchaser
The big block build is done in fact finished it on Tuesday night this week I can throw up some specs if your interested though
"Orange Crush"
Old 04-09-2016, 04:24 AM   #6
Blue Rat
I'm watching this build. What heads?
Old 04-09-2016, 12:45 PM   #7
Valarius_Starchaser
Here's a few pictures of the block and rotating assembly all at home This took me A Friday night until 1am and then about 16 hours the following Saturday to complete I just kept working and working
"Orange Crush"
Old 04-09-2016, 12:47 PM   #8
Valarius_Starchaser
The heads that I went with are simply a money issue they are 119cc 781 heads that I ported and polished/gasket matched back when this engine was still in my 65 Impala then it had stock rods and hyperutectic flat tops. The impala was traded for the truck and I kept the engine.
"Orange Crush"
Old 04-09-2016, 12:51 PM   #9
Valarius_Starchaser
now to the bump stick I went a little cheaper here too with a full roller in the future BUT I am following a Super Chevy article "budget build" for some of this to accomplish similar power numbers
Camshaft= http://www.summitracing.com/parts/sum-k1303
I also installed my own cam bearings that Friday night so nobody gets to worried that I'm insane and would skip that step
"Orange Crush"
Old 04-09-2016, 12:56 PM   #10
Valarius_Starchaser
Then when I went to put the head gaskets I had ordered on I found that I had a problem with some cooling passages in the head being not drilled on my early block I contemplated cutting the gasket where the original cooling passage was but without any sealant around that area on the gasket I feared the worst if I did it so I forged ahead and went full speed ahead drilling the block even after it was nearly fully assembled
"Orange Crush"
Old 04-09-2016, 12:59 PM   #11
Valarius_Starchaser
That same evening I had to cut down my valve guides to accept positive seals and double springs for such a high lift cam with no time to waste being that it was Monday night I got both heads cut and one on installed and torqued
My springs = http://www.alexsparts.com/dual-valve...appet-396-502/
I went for the 115lb seat pressure set following along with a set that summit tech support recommends seat and open pressures
"Orange Crush"
Old 04-09-2016, 01:06 PM   #12
Valarius_Starchaser
Now its all together and done shoved back into the corner until I finish rebuilding my 4L80E which I just tore apart Thursday night no rest for the weary as they say
"Orange Crush"
Old 04-14-2016, 08:56 PM   #13
Blue Rat
I have been up most of the night last night working. Maybe it is just me. But those pistons don't look right in that block.
Old 04-14-2016, 09:08 PM   #14
Valarius_Starchaser
Yah uhm fail on my part that's what happens when you don't stop for 12+ hours they were indeed upside down fixed it a few nights ago
Regan Wilson pointed it out
no one else to blame but myself
"Orange Crush"
Old 04-14-2016, 11:19 PM   #15
Blue Rat
n one else to blame but myself
It happens. This first time I been back here. I like those valve covers. Looking good.
