Old 04-03-2016, 10:51 AM   #1
chinquipin
1985 K20 transfer case
Just purchased a '85 K20. It has sm465 transmission and np208 transfer case. The transfer case housing is busted (chain came through housing). What all years will work without doing any major modifications? I would like to have a np205 but that isn't a necessity. Thanks for any information.
1950 Chevrolet 3100
2006 Silverado Crew Cab
Some other scrap
chinquipin is offline   Reply With Quote
Old 04-03-2016, 11:36 AM   #2
ryanroo
ryanroo's Avatar
Re: 1985 K20 transfer case
Any 208 from a th400 or 465 truck will swap in directly. they are in 1500 an 2500 trucks from 81-87? a 205 from an 85-91 K30 will bolt in as well. you will need a few of the associated goodies from the 205 truck to make it an oem looking install, but the hard parts bolt together.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-03-2016, 03:06 PM   #3
chinquipin
Thanks for the info!
1950 Chevrolet 3100
Some other scrap
Old 04-04-2016, 02:08 AM   #4
andrewmp6
Yeah you should have no problem finding a np208 its really common.
andrewmp6 is offline   Reply With Quote
Old 04-04-2016, 09:10 AM   #5
chinquipin
I didn't figure they would be too hard to come up with. I've just now started looking. I have a friend that has a couple older 205s. I haven't saw them yet but i assume they are the figure 8 pattern. I guess I will just put a 208 in for now and if i happen to stumble across a 205 change it later.
1950 Chevrolet 3100
Some other scrap
Old 04-04-2016, 02:50 PM   #6
obijuan
You can get them from cucv part outs very common. Any 85 + passenger drop 32 spline tcase can bolt up. 205 will need the round pattern adapter with it. 241 from an 89 burb or k5 will work too. After that they are vss.
obijuan is offline   Reply With Quote
Old 04-10-2016, 11:39 AM   #7
CrewCab59
CrewCab59's Avatar
I have few Np208 if needed. What part of Tn ?
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 04-10-2016, 05:09 PM   #8
chinquipin
[QUOTE=CrewCab59;7555213]I have few Np208 if needed. What part of Tn ?
Thanks[/QUOTE
I haven't got one yet. Haven't been looking too hard. I wanted to pull mine out and confirm 100% what i needed before i bought one. I've been pretty busy and haven't had time yet. I'm just a little over an hour from you. If you don't care pm me your number and i will give you a call. Thanks
1950 Chevrolet 3100
Some other scrap
Old 04-10-2016, 06:16 PM   #9
CrewCab59
CrewCab59's Avatar
[quote=chinquipin;7555594]
Thanks[/QUOTE
Pm sent , I have a few of them if you need 1.
1971 Chevy C/10
