Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 04-03-2016, 11:58 AM   #1
dennislbrooks
dennislbrooks's Avatar
42 front radiator skirts and baffle
With the 42 on an s10 frame, I have begun to make the templates for the front radiator skirts and the bottom baffle. I used 1/8" ABS pebble sheet for the side engine shrouds/skirts and plan on using the same for the 4 pieces in front of the radiator. I did not have to paint the ABS as the black pebble surface looks pretty good. This is to cleanup the front behind the grill. I will have to use a small angle to support the 33" bottom baffle and will add a vertical skirt to it also. Will post a pick.
dennislbrooks is offline   Reply With Quote
Old 04-03-2016, 03:29 PM   #2
dennislbrooks
Re: 42 front radiator skirts and baffle
OK-hard to see the cardboard templates but both sides and bottom plus i will put a vertical on the bottom.
