04-05-2016, 11:25 PM | #1 |
Silent Coat Sound Deadener
Here is the first of many products we will be advertising on the Forum for all of our C10 Truck Friends.
Silent Coat Sound Deadener is a great affordable product that will make a good truck great. About the Product: Our New 2mm Vibrodamping Material-Black uses mass loading to lower panel resonance and absorb structural vibrations, converting them into low level heat. Stop those nasty rattles, eliminate road and outside noise, insulate your vehicle and dramatically improve the sound of your car audio stereo system. Our vibration damping products are a polymeric based damping material with a supercharged adhesive. With an Aluminum surface and a unique military-grade composition, it has been proven to be extremely efficient at the conversion of vibration to thermal energy. Silent Coat is very flexible which is very important to the installer, as it allows it to properly adhere to a contoured panel. This product can be installed anywhere in your vehicle, but is mainly installed within door panels both inner and outer and roof. With military grade construction and highly effective damping, Silent Coat sound and vibration damping are already the choice of many car audio companies.
$90.00 Per Box Visit: http://www.gsimfab.com/silent-coat_8_4270.html |
04-06-2016, 02:18 PM | #2 |
Re: Silent Coat Sound Deadener
This is the Silent Coat 2mm silver $85.00
Last edited by GSIMFAB; 04-30-2016 at 01:55 PM. Reason: include price for product |
04-30-2016, 01:48 PM | #3 |
We just finished damping this 79 C10 truck.
This truck was sound damped with 4mm on the firewall for additional heat resistance and 2mm everywhere else. Silent Coat Stop those nasty rattles, eliminate road and outside noise, insulate your vehicle and dramatically improve the sound of your car audio system. |
04-30-2016, 06:06 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
How much to do a truck cab?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-30-2016, 08:31 PM | #5 |
On this truck we used 3/4 of a box of the 4mm for the firewall and trany hump and 1 1/2 boxes of the 2mm. The 2mm Boxes cover 21.5 SQFT each and the 4mm covers 15.36 SQFT. If you were doing a cab then 2 boxes of 2mm would cover you. I would probably buy an extra box that way you could damp the doors also.
05-25-2016, 12:34 AM | #6 |
