Old 04-06-2016, 07:54 PM   #1
Dave0
Zr2 rear in a second gen 55
Anyone use the springs, and perches out of the s10?. (Changing to s10 perches) I got a smoking deal on one, they cut the frame off at the back of the cab and sold it to me. The track bar is there too but I dont think I will be using it. I would like to put the whole thing in, springs, spring mounts and rear end.
Ive searched all over and came up empty...
Dave0 is offline   Reply With Quote
Old 04-06-2016, 09:46 PM   #2
Mac the Yankee
Re: Zr2 rear in a second gen 55
Not sure about the S10 rear- check your width from drum to drum.
I'm using a rear out of a '77 Z28 that fits like a glove in my TF.
Mac the Yankee is offline   Reply With Quote
Old 04-06-2016, 09:49 PM   #3
Rude Dude
Rude Dude's Avatar
S10 will be narrow and mounting springs might not work on TF, it might work on AD truck.
Rude Dude is offline   Reply With Quote
Old 04-07-2016, 12:33 AM   #4
Crash0637
I just sold my S10 ZR2. The rear in that particular truck is quite stout. I don't remember the exact specs. However I do know that it is 4 inches wider than the stock S-series.
As far as using the ZR2 suspension. In my opinion it is pretty heavy duty. If you are building your truck to be a 4x4 then yes use these spings, but if you are looking at lowering the truck, there are better options out there.
Crash0637 is offline   Reply With Quote
Old 04-07-2016, 07:36 AM   #5
Dave0
Yes it will be lowered.
I do have a set of springs on the zr2 clip and I have a pair of stock 2wd s10 springs also. Also with all of the brackets on them...
