Old 04-07-2016, 08:41 AM   #1
Nodnarb76
Nodnarb76's Avatar
Vaccum source for heat/ac control.
Starting to wrap up my LQ4 swap, and one of the last small details I have overlooked is where to attach the very small hose for my heater/ac control?
This hose is really small and I'm not sure what to hook it to.
Heard there may be a tab on the stock intake I can remove and use.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-07-2016, 12:25 PM   #2
First c10
First c10's Avatar
Re: Vaccum source for heat/ac control.
I put a tee in the brake booster line at the back of the intake and ran it to the stock AC ball canister then inside to the heater/AC control
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-07-2016, 03:09 PM   #3
ls1nova71
ls1nova71's Avatar
If you are using a truck intake, then there is a little tab you break off for a vacuum source. There are pics in my build thread, post 204. http://ls1tech.com/forums/conversion...c-10-a-11.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-07-2016, 03:48 PM   #4
foamypirate
foamypirate's Avatar
What this guy said. Passenger side of the intake towards the rear.
foamypirate is offline   Reply With Quote
Old 04-07-2016, 04:17 PM   #5
First c10
First c10's Avatar
It made me a little nervous to brake that off. If it brakes flush your screwed. Time for new intake. But that is a perfect place to attached that vacuum line.
GO GO!!!
Old 04-11-2016, 12:07 PM   #6
Nodnarb76
Nodnarb76's Avatar
Could I just cut off the tab to make sure it doesn't break off flush?
Also my climate control vacuum hose is really small. I'm worried it won't fit on that nipple.
Old 04-11-2016, 01:38 PM   #7
First c10
First c10's Avatar
don't see why not!
GO GO!!!
Old 04-11-2016, 04:13 PM   #8
Nodnarb76
Nodnarb76's Avatar
Here is the really small hose I'm talking about. Anyone know what size this is?
Old 04-11-2016, 04:20 PM   #9
First c10
First c10's Avatar
I just ran a new vacuum hose from the ball/vacuum canister to my vacuum source. I think I used 3/16"
Is the hose in the picture hard tubing? Or soft rubber? And where does the other end go?
GO GO!!!
Old 04-12-2016, 09:09 AM   #10
foamypirate
Looks like the soft rubber end has broken off of your vacuum tubing (not hose). That should feed into the cab through a grommet on the passenger side of the firewall. You can get all sorts of vacuum tubing elbows and splices at the auto parts store to repair it, usually in the HELP! section. You should have a vacuum hose from the port on the intake, into a check valve, and then the check valve has two outputs, one for that vacuum tube, and one to the vacuum ball.
Old 04-12-2016, 10:28 AM   #11
Nodnarb76
Nodnarb76's Avatar
Hmmm, Sounds like I may have taken off more than I needed to when I pulled the motor out. Good news is I know exactly where the vaccum ball is. but have no idea where the check valve went.
Old 04-12-2016, 02:52 PM   #12
foamypirate
The check valves are available in the HELP! section of most parts store, so no sweat there. They are only a couple bucks.
Old 04-12-2016, 02:58 PM   #13
First c10
First c10's Avatar
Check valve? Ok I am not sure I have one. What is the reason for a check valve on the vacuum line to the AC system?
GO GO!!!
Old 04-12-2016, 03:01 PM   #14
foamypirate
The check valve, along with the vacuum ball, maintain vacuum for the climate control when the engine is under load (no manifold vacuum). In a nutshell, it keeps the control doors from going crazy when you mash the throttle.
Old 04-12-2016, 03:04 PM   #15
First c10
First c10's Avatar
Ok I got that. I thought it was already in the ball? I haven't noticed any problems but maybe that's because I have a stock lc9 motor.
GO GO!!!
