Old 09-26-2003, 11:29 AM   #1
67chevemall
67chevemall's Avatar
Big Knock in enigine Bottom end?????
My buddies truck just broke down!! He is in the dark ages so I thought I'd ask the pro's for him! Just wondering if any one has any idea what the problem could be????? The moter blew a gasket and spit the oil out on the highway. The motor still runs fine, but makes a loud Knock Knock Knock Knock !!!!!!!Knock!!!
Any Ideas??
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-26-2003, 11:31 AM   #2
dubie
dubie's Avatar
sounds like he spun a main bearing and it's worn into the crank. This causes the connecting rod to knock against the crank since it's loose now.
Just my guess
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-26-2003, 11:38 AM   #3
jef5150
Inline 69
jef5150's Avatar
i had a connecting rod "wrist pin" go bad,,,my knocking noise on deceleration,and idle only,,like you said the motor ran fine,,no noise under load
jef5150 is offline   Reply With Quote
Old 09-26-2003, 12:34 PM   #4
67chevemall
It knocks at idle and when you drive it! We drove it home about 15miles and nothing changed same knock while it's running!
Old 09-26-2003, 12:40 PM   #5
tom hand
CCRider
tom hand's Avatar
It won't be long before he finds the problem...it will be sticking out of the side of the block
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-26-2003, 02:35 PM   #6
oldsub86
Either look for another engine or tear it down now. If you keep running it - it won't be for long.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 09-26-2003, 02:36 PM   #7
krue
Designated A-hole!
krue's Avatar
Stick a fork in it it's done! All he's doing now is circulationg bearing material throughout the block. Park and rebuild!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-26-2003, 03:04 PM   #8
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
time for a rebuild a rod thru the block is not a nice pic
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 09-26-2003, 03:15 PM   #9
67chevemall
Thanks guys!
He just called and he took the oil pan off to see if it is a 4 Bolt Main so he doesn't get ripped off! I told him to rebuild it himself but he is worri!!
Time for a rebuild Book!LOL
Cheers
Old 09-26-2003, 03:58 PM   #10
Class of 69
Class of 69's Avatar
It will need a crank for sure, and if it is a main that spun, the block will be toast as well. I wouldn't get my hopes up until I determined the source. It may need to be completely replaced....HHHmmm good time for a ZZ4???!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
