Remote Trans Cooler
Ok wasn't sure if I should post here or in the engine & drivetrain section but think this might be better here. I am currently building a 67 with 6.0 & 4L80e swap and ordered a transmission cooler for the truck. The truck will eventually get a decent sized cam and aftermarket converter and wanted to make sure I bought a cooler that would keep the trans cool enough for primarily street use and light track use.
This is what I ordered for a standalone cooler. http://www.summitracing.com/parts/der-13950 When I called Derale though, the tech guy said I should order this cooler if I wanted to run the cooler as a standalone because he said the 13950 would have to be run with the radiator trans cooler to keep the trans cool enough especially with a high stall converter. http://www.summitracing.com/parts/der-13960?ibanner=MobileSwitchNo So I guess the question is, should I go though the hassle of returning the cooler I bought and get the 13960, or will I be ok sticking with the 13950? Other than difference in thickness, they don't seem seem that different to me. And I'd prefer to not have to use the radiator cooler.
71 Longhorn 402, PS, PDB, AC, Tach, Posi 67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress) 2002 Victory Red ECSB Silverado 5.3 (DD) |
meowMEOWmeowMEOW
Re: Remote Trans Cooler
I'm running a slightly more aggressive version of the same setup, and using a Derale cooler like that. Mine looks like the first one, but I'd have to check my receipt log for a part # (I have the install of it in my build tho).
I don't run it through the radiator, and I've been pretty happy with my trans cooling thus far (like 5 years now...damn time flies). Haven't seen trans temps over engine temps at any point I can remember, from 55-105* ambient.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
It's Better With Nitro
I also run an older Derale fluid cooler similar to the first one, but also utilize the radiator tank. I do this mainly to help stabilize the temperature once the trans fluid reaches operating temp.
Brew,
I think it was from your build thread that I think I got the idea for the derale fan cooler in the first place. ![]() Vin63, The derale tech told me I should run the cooler I have with the radiator tank like you did because he said my cooler alone (the first link) would not be enough to cool a stalled 4l80e. So what do y'all think, am I just paranoid about using the radiator tank for transmission cooling? Everything I've read on the subject is real back and forth on whether you should use just a standalone cooler, or whether you should use a cooler along with the radiator tank. Some folks say in a performance application it's best to just use a standalone cooler, due to risk of coolant getting in your transmission lines which is the main thing that has me worried about using the radiator & cooler for transmission cooling. I definitely appreciate y'all getting back to me so quickly. I jut need to figure out if I should keep the cooler I have now and use it with the radiator, or return it and get the other model the tech recommended for standalone use. Thank y'all again! -Zak
Fyi.. I used to run a junk tube fin style cooler with the 4l80e and a 4,900 rpm verter. The trick is to lock the verter in second gear rifht away at <50% throttle and keep it locked. Trans temp while cruising were a mere 145-150* in 85* weather.
You can't create heat when it ain't slipping...
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
