Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-15-2016, 12:49 PM   #1
Ralph's '85
1985 gmc radio questions
Hi,
I have a 1985 Sierra with the stock radio. It didn't work at first, turns out the fuse was blown so I replaced it and it worked. But when I drive the truck the fuse blows every time even if the radio is off. I am using a 15 amp fuse. Is this the correct size? Thanks
Ralph's '85 is offline   Reply With Quote
Old 04-15-2016, 03:40 PM   #2
ranger danger
ranger danger's Avatar
Re: 1985 gmc radio questions
Sounds like its grounding out somewhere. Most basic radios don't need more than 7 amp fuses.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 04-15-2016, 05:06 PM   #3
Ralph's '85
The weird thing is the fuse will only blow when driving in overdrive (700r4). Regular drive is fine. Any ideas?
Old 04-15-2016, 07:58 PM   #4
ray_mcavoy
Yes, 15 amp is the correct size fuse for this circuit because it powers more than just the radio. This circuit also powers the 3 "ACC" (accessory) receptacles in the fuse box. Those are used to supply power to various options such as the 700R4 lock-up torque converter solenoid, 4 wheel drive indicator light, and auxiliary battery relay.
I can't find many details on the 700R4 wiring in the 1985 wiring diagrams but the 1986 diagrams have some info. It appears as though many of them have a switch inside the transmission that closes when the 4th clutch (overdrive) is engaged. That feeds power to the torque converter clutch solenoid which should have a resistance of 23.5Ω. So a short to ground in the wiring (internal to the trans) between that switch & the solenoid or a shorted solenoid are a couple possibilities that could cause the radio fuse to blow only when the trans is operated in overdrive.
ray_mcavoy is offline   Reply With Quote
