Old 04-16-2016, 07:24 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
V8 Motor mounts
Switching out the straight 6 for a V8 small block.
What are the best motor mounts to use?
Anything else that I should be aware of as far as the swap?
'63MurderTruck is offline   Reply With Quote
Old 04-16-2016, 09:23 PM   #2
Atbyrne
Atbyrne's Avatar
Re: V8 Motor mounts
I just installed a 327 in place of the original 250 6. I used the same mounts.
1966 Chevy C10 2WD SB
Atbyrne is offline   Reply With Quote
Old 04-17-2016, 12:18 AM   #3
Captainfab
60-66 Nut
Re: V8 Motor mounts
There is no need to change anything unless your I6 was a 292. If your I6 was a 230/250, the small block just drops in the exact same place with the same engine mounts. That is how/where GM originally installed them.
Old 04-17-2016, 01:31 AM   #4
jtrichard
Re: V8 Motor mounts
IF you are replacing with NEW mounts you might consider poly mounts they last a life time
jtrichard is offline   Reply With Quote
Old 04-17-2016, 10:52 AM   #5
padresag
Re: V8 Motor mounts
a lot of those old rubber mounts have been around for 50 years. that is pretty good service.
ron
padresag is offline   Reply With Quote
