Roof swap
Has anyone swapped the outer roof panel? I have a donor roof, just looking for the best way to go about it. It seems that part of the panel is bolted on and the front and the rear corners are pinched welded.
Re: Roof swap
if you're talking about just the skin you'll need to drill out all the spot welds around the drip rails and cut along the rear posts. i did one that was an ambulance with lifted roof and put a regular skin on.
you never have too many suburbans.... |
BlahBlahBlah
Re: Roof swap
Wow, that sounds like a ton of work.
The Older Generation
Re: Roof swap
Here are some pictures of the spotwelds and bolts.... LockDoc
Re: Roof swap
Mine was cut half way up the flat part above the rain gutter. Can't tell any where
![]() Join Date: Apr 2005
Re: Roof swap
Hey Doc, what manual did you pull that from? Do you have a ISBN or part # for it? Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#7 | |
Re: Roof swap
It is out of the CD version of the '67-'72 Assembly Manual. It has a "Find" function and you can actually search for words. http://www.ebay.com/itm/1967-68-69-7...-/400609780890 http://www.classicparts.com/1967-72-.../#.Vz3vgCHVrTo If you do some searching you might be able to find it a little cheaper.... LockDoc
#8 | |
Re: Roof swap
Re: Roof swap
Did you end up with the 4x4 suburban that the car hauler company crushed the roof ? Looked like a nice burbn
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
