04-29-2016, 03:23 PM | #1 |
wheel backspace
I know this topic comes up a lot.I have 20x8.5s 5.25BS and 20x10s 5.5BS on my truck now. im bagging the truck and putting in a bolt-in C-notch. Is my backspace good for a bagged track? 72 rearend
04-29-2016, 03:29 PM | #2 |
67-72 parts collector,…
Re: wheel backspace
Sure.
But you have the answer right in front of you. Remove the springs and lay the truck out. You will need an adjustable track bar to re-center the rearend. Seems like you could tell us if this will work, instead of the other way around. Use quality shocks and rear shock relocators also. Trim any bumpstops or brackets that are in the way.
04-29-2016, 03:39 PM | #3 | |
Re: wheel backspace
Only thing is I have the bed and the wheels off right now to install the airbag kit. I kinda wanted to get some new wheels before the price goes up next month. but I guess I could measure.......... |
04-30-2016, 03:27 AM | #4 |
Re: wheel backspace
For 80 bucks you can buy a percys wheelrite that will let you test out any rim size and backspacing you can think of.
04-30-2016, 01:30 PM | #5 | |
Re: wheel backspace
Travis |
05-01-2016, 01:01 AM | #6 | |
motor exploder
Re: wheel backspace
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
