Old 05-06-2016, 01:35 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Rerouting my brakelines, prop valve question.
My truck (66) was running manual brakes with a front disc conversion (72 front end stuff) when I bought it from the PO years back. It has a Wilwood adjustable valve on the rear brakeline which I've used a bit to keep lockup reasonable with my big old drag radials.
Since then I've switched to the Wilwood D52's and Hydroboost, but retained the drums out back. I used the master and boost unit from a 97 Astro, and my existing brakelines hooked up with little issue....however....
I need to finally redo the line routing in a much more appealing setup, and realized that I don't think I've ever had any sort of proportioning or bias controlling valve on the truck (sans the Wilwood unit mentioned in the beginning).
Should I actually be running one? Is the bias valve in the back doing enough? My trucks braking has been pretty great since the upgrades and I don't really "feel" anything wrong, but as it starts running faster ET I have to scrutinize my safety and brake setups a ton more.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-06-2016, 07:17 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Rerouting my brakelines, prop valve question.
I think the Wildwood adjustable unit is totally acceptable. If you put something else in the system then you would be "double proportioned".
Also - big tires on the rear are directionally correct. They help minimize lockup as well.
If the brakes feel good now I'd leave them as they are and make a design change later if required.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-07-2016, 06:53 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Keith. I'm just so used to seeing the prop valves that stock setups use that I'm second guessing it. I have maybe 4 things on the truck that are remnants from the PO, and I question them all
