Old 05-22-2016, 12:15 PM   #1
dme922
dme922's Avatar
5.3 injector/harness???
I have a harness to fit a 04 5.3 but my motor which i thought was a 04 has a different injector plug than my harness. The pins in my injectors are offset and the harness is in the center. So are my injectors considered the ev6 and my harness ev1?
dme922 is offline   Reply With Quote
Old 05-22-2016, 01:47 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3 injector/harness???
Trucks had a MultecII connector, assuming you've got the short-fat injectors.
For comparison
EV1
Ev6
MultecII
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-22-2016, 02:02 PM   #3
dme922
dme922's Avatar
Are the pin locations different on older motors? The pins on my injectors are more to the bottom and on the harness i have it looks centered.
Old 05-22-2016, 02:10 PM   #4
dme922
dme922's Avatar
My injectors look like this
Old 05-22-2016, 03:59 PM   #5
dme922
dme922's Avatar
My harness is made to fit this type
Old 05-23-2016, 01:50 PM   #6
boostedc10
boostedc10's Avatar
Your injectors are EV6, the harness is set up for multecII. They sell adapters or you can just change the plugs and terminals. Wiring is the same.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 05-23-2016, 02:18 PM   #7
dme922
dme922's Avatar
Thanks for your help. I just talked to a guy at casper electronics about this adapter.
