Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-24-2016, 12:34 AM   #1
PebbleHill
Looking for suggestions for my Street and Some Strip 72
Hi guys, I've been doing some upgrades on my old 72 SWB and I'm at a crossroads. To spray or not to spray. Truck started out as a weekend toy and ended up at the drag strip and I love it ! Built the stock 350 .30 over, SRP Forged flat tops, Vortec heads with screw in studs and guide plates, 500 lift solid flat tappet cam,254/254 at.50 and 110/118 llobe Sep ,MSD pro billet distributor,6AL box with 6200 pill,Stock crank polished and balanced, forged Scat I beam rods, RPM Air Gap intake, AED 750 HP/HO carb, TH350 with shift kit, 2600 Stall, Detroit True Trac rear end with 373 gear and 275/60/15 on 8 in rally it went 8.30 at 80 mph. 60ft sucked at 2.1 on street tires..Looking at getting some new MT ET Street SS in 275/60/15 or ET Street R in 255/60/15 to give me a little more gear..What would you next besides drag radials to get me in the high 7"s and still be stretchable ?
Tapped the rings for a 150 shot but want to get in the 7"s without NOS.
Mark
PebbleHill is offline   Reply With Quote
Old 05-24-2016, 03:02 AM   #2
PebbleHill
Re: Looking for suggestions for my Street and Some Strip 72
Streetable not Strechable ! Damn autocorrect
Old 05-24-2016, 07:37 AM   #3
Blue Rat
Thats a whole lot of .050 for that engine combo. Just a thought. Also I would start with trying to get the 60 ft time to drop off some. Of course without NOS.
Blue Rat is offline   Reply With Quote
Old 05-24-2016, 10:07 AM   #4
Super73
Super73's Avatar
I was thinking along the similar lines, 254* @ .050 is a lot for that little of cubic inches and paired with a 2,600 rpm converter is adding to the lack of 60'.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-24-2016, 12:31 PM   #5
djracer
djracer's Avatar
What have you taken out of it weight wise? What shock and spring are you running? I am assuming it is still trailing arm. What gear?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-24-2016, 07:36 PM   #6
Blue Rat
Is that 750 a DP or Vacuum secondary?
Old 05-24-2016, 08:51 PM   #7
PebbleHill
The truck is stock 3900 lbs so no weight taken out. I'm running a 373 gear. And the AED carb is a double pumper,75 jets in the front and 85 in the rear. I called AED and told them what I had and that's what they sent me..As far as shocks it's bone stock but I'm about to adjustable for front and rear and yes it's still trailing arm . Thanks
Mark
Old 05-25-2016, 07:32 PM   #8
Blue Rat
I think these two changes would help.
http://www.summitracing.com/parts/cc...make/chevrolet
750 Vac.
Just my thought.
Old 05-31-2016, 09:45 PM   #9
19671972C10
Oh yea convert to roller cam and roller lifters.
19671972C10 is offline   Reply With Quote
Old 06-05-2016, 07:53 PM   #10
Blue Rat
Well, hope he didn't get aggravated. I was just posting my thoughts on what I though could help.
Old 06-06-2016, 12:45 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
He hasn't logged in since 5-25 and only has a few posts. Maybe he hasn't even worked on it, or maybe he just popped in for some info and thats it (it happens a lot, and thats ok). I wouldn't worry too much about it dude.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
