Old 05-26-2016, 09:54 AM   #1
1moretoy
Steering column plug? Need Help.
I'm trying to install my new column and can't get the plug from the wiring harness to the steering column to mate. Do I have the wrong plug on either side? I cant get them to line up.
1moretoy is offline   Reply With Quote
Old 05-26-2016, 10:45 AM   #2
haycatcher
Re: Steering column plug? Need Help.
looks like the end wires need to move down a cavity to line up?
haycatcher is offline   Reply With Quote
Old 05-26-2016, 10:47 AM   #3
snipescastle2
snipescastle2's Avatar
At first, I didn't notice the two plugs on top of each other, You might have to get a used connector from a salvage yard and change the pins from the new plug provided, out to the old connector.
I know in most situations the adapter GM sells that mates the flat long connector you have to the "Half Moon" original style, as do most of the vendors here on the board, it's about $10-$20.......not sure who would have a new connector for the newer style flat connector. might try M&H Electrical Fabricators.
Ben
http://www.classicparts.com/1967-72-.../#.V0cMb032aM8
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 05-26-2016, 01:28 PM   #4
snipescastle2
Talking Re: Steering column plug? Need Help.
one more thing, did you buy an aftermarket wiring harness? it should have came with all the mating connectors, if not, you might call the supplier or company that made it...
Ben
Old 05-26-2016, 03:31 PM   #5
1moretoy
Yes I'm using a american wiring harness highway 22 series.
Old 05-27-2016, 10:44 AM   #6
snipescastle2
I found an extra plug, like the one on your harness. If you would like me to send it to you, send me a PM with your info....
here are a few pics...
Ben
Old 05-27-2016, 10:42 PM   #7
1moretoy
Ben
Thank you for the offer. I found a connector at work and it is the same one you have. Came home and it plugged right in
