05-29-2016, 09:30 AM | #1 |
Tow hooks again -- oem
On a 67-68 --10-30 -- do the left and right oem tow hooks points ---point the same way or opposit? I have read every post I could find on here and see only one part number for the 60-68 without a left or right differenciation. I see pics where the points are the same way and some where they are opposite.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
05-29-2016, 03:25 PM | #2 |
Re: Tow hooks again -- oem
I don't know what to say about only one part#. All tow hooks differ from left to right except some of the '72s.
05-29-2016, 07:45 PM | #3 |
I saw 2 pair of fronts at the Springfield swap meet this weekend --- p/n 3663349-50--- all 4 point to the left if mounted with opening back. I bought one pair and all had the same part number.
Maybe I need to trade for a right --- the mounting surface is the same on both sides. If you look at this post points are the same direction for a 67-68 in top pic and opposite in a lower pic. http://67-72chevytrucks.com/vboard/s...d.php?t=378030
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 05-29-2016 at 07:52 PM. |
06-04-2016, 11:59 AM | #4 |
Frontwards , backwards, right, wrong -- supposedly these correct 60-68 tow hooks in my opinion are overkill for a 1/2 ton or 3/4. I bought the pair and they had what I think are the original 5/8" grade 8 fine thread bolts and I mounted them with 4 new grade 8 coarse threads with the thick washers and lock washers on the inside. I used 69 front leaf spring hangers --I do not know if they differ in design of a 67 K10 but there was little room for mounting them on the frame.
As I said earlier they both curl the same direction which is not noticeable but either correct or incorrect. If anyone has a pair of p/n 363349-50 that curls opposite mine I will trade you one. There is no gm info I can find and it appears that 67-72 has more info -right or wrong- on them than anywhere on the web. My assembly book does not show them at all.
