05-29-2016, 08:55 PM | #1 |
Rear Frame Repair 71 K10 Shortbed
Hello all, I am going to be repairing the rear frame of my truck. The damaged section of frame is in the back behind the leaf spring perches, where the bumper mounts attach to the frame. It's a classic case of previous owner damage, finally being repaired. I believe the frame was damaged in an accident and then repaired using junk. Summarization of the issues: welded in trailer hitch, spring perches welded on, rear cross member cracked in half, bottom rear 7" of frame rail missing. I am going to attempt to fix all of these issues and after completed install a Curt 14082 trailer hitch and an Aerotank 40 gallon gas tank. I know this may seem like a lot to do, but I've had classes in welding, completed larger automotive tasks. I am also looking forward to having a functional trailer hitch and much larger gas tank. As I progress through the repairs I will be posting pictures to assist others in the repair process and to ask for advice as one off questions arise. Look forward to hearing from you all!
Bryan B. 1971 K10, SWB, 350, TH350, 8" Lift, 35" tires, Etc... |
05-30-2016, 12:41 PM | #2 |
Re: Rear Frame Repair 71 K10 Shortbed
Well, the welded in tow hitch is now gone. The welded on spring perches have been removed and replaced with another set of factory perches, bolted in where the originals were riveted. The next step is to carefully remove the remaining pieces that have been welded to the frame. After this I plan to start mocking up the the frame repair pieces. I plan to use original frame material pulled off a junk yard truck to replace and then add extra support with frame stiffner sections welded in. I have attached some pics of the remaining damage.
Bryan B. |
05-30-2016, 01:55 PM | #3 |
All about them K’s
Thats a mess no doubt about it. Looks like you've got the right idea to me.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
06-21-2016, 02:11 PM | #4 | |
PITbut
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
06-22-2016, 10:34 AM | #5 |
Ok, so here is a pic of how bad the rear crossmember is in it's current state. It was previously cut out and then actually cracked in half. I looked over my entire frame after seeing this, thank goodness no cracks.
06-22-2016, 10:35 AM | #6 |
Pic of new crossmember from ECE...
06-22-2016, 10:38 AM | #7 |
So, I removed all the welding with an angle grinder on the driver's side frame rail. It took a good deal of time, trying to remove old cross member by grinding out rivets...
06-22-2016, 03:26 PM | #8 | |
Still plays with trucks
I made some drill centering fixtures of varying sizes on the lathe that I could put over the head of the rivet no matter what the crushed diameter was and get the drill hole close to the center of the rivet. Made things much easier and quicker.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-22-2016, 03:59 PM | #9 |
All about them K’s
I always just grind the head off one side and let the air hammer do the rest. If your good with the grinder there is no frame damage.
06-23-2016, 08:59 AM | #10 |
Grinder and air hammer is my current method. That air hammer is a beast of a tool!
08-14-2016, 08:55 PM | #11 |
Update, the rear passenger frame was previously welded by someone that did not do a very good job, at all. I spend a few hours grinding down the welds. When I got to real metal I found at least two cracks in the last 6" of the drivers side frame, turns out the cracks are from misc plates being welded in as repairs. My current plan is to remove the last 6" section of frame and replace it with a piece out from a donor truck. It will be painful cutting out the damaged section and replacement piece, but worth it for piece of mind. After the two pieces are ready I'm going to have them TIG welded together (by a professional) and then I will grind down the excess and paint to match. Please see the attached for pics of what it looks like after the last work performed. Thanks for following...
Bryan B. |
10-21-2016, 07:32 PM | #12 |
Hello all, please see the below for pic updates for the frame job. I cut out the damaged section and replacement piece. I used a dremel for the cutting and a rasp to do final fitting, it actually fits really really well! Thanks for tuning in.
10-21-2016, 07:47 PM | #13 |
All, the welding job has been completed. I took two pics of the frame so that I could post them and the fantastic results. It looks almost perfectly stock, although I still have to clean up the welds on the inside tomorrow. I am really stoked, now to install the trailer hitch and bumper. More to follow...
10-22-2016, 11:12 AM | #14 |
All about them K’s
Very nice!!!
10-22-2016, 11:36 AM | #15 |
I just did the same basic thing to a 12 Silverado crew cab Z71.
On the rivet thing also a good method is to take a die grinder and make a huge X in the rivet, then you can pop the head off easier. Then as with the method posted above you can take the air hammer and drive out the offending little rivet. In my shop I have on occasion needed to replace a frame spring hanger or something similar, I've bolted on a replacement with grade 8 bolts a little long and double nutted them then tacked the out side nut to the bolt. Out of the ones that I have done that way never a problem |
