Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 07-03-2016, 12:07 AM   #1
whateverpratt
5.3 complete takeout
I pulled this from an '05 GMC 4x4. Mileage unknown. The harness is not cut anywhere. The DBW pedal, harness, and controller are included as well as the computer, stock manifolds, shorty hugger headers (center dump), AC compressor, power steering pump, original motor mounts, gen 3 to gen 1 motor mount adapters from advance adapters, radiator and fans, stock airbox, fusebox, generic inline fuel pump (same as walbro 255), AN fittings and connections, high pressure fuel line, flywheel, and clutch.
I bought this to put in my truck, but ended up going a different route. You'll have everything you need to run this engine except for the corvette filter/regulator. The only modifications were to the computer and the flexplate/flywheel. I had the computer reprogrammed for a manual transmission and had the VATS, emmisions, and post cat 02 sensors deleted. The flexplate was removed, and I installed the sachs flywheel along with a standard 12" clutch (the flywheel is drilled for both new and old clutches) with a 10 spline disc (I was planning on running a, NV4500, but this setup up will work with anything from an SM420 to a muncie to a t56). I followed this thread to put together everything for the manual trans:
http://ls1tech.com/forums/conversion...-ls-motor.html
See below for prices
whateverpratt is offline   Reply With Quote
Old 07-03-2016, 12:09 AM   #2
whateverpratt
Re: 5.3 complete takeout
pics
Old 07-09-2016, 09:50 AM   #3
whateverpratt
Split up the prices look like so
Engine only SOLD
Uncut unmolested harness SOLD
The DBW pedal, harness, and controller SOLD
ECM/PCM computer SOLD
Coils SOLD
stock exhaust manifolds $50
shorty hugger headers (center dump) SOLD
AC compressor SOLD
power steering pump SOLD
original motor mounts SOLD
gen 3 to gen 1 motor mount adapters from advance adapters SOLD
radiator and fans SOLD
stock airbox SOLD
fusebox SOLD
generic inline fuel pump (same as walbro 255) $75
AN fittings and connections SOLD
high pressure fuel line SOLD
flywheel SOLD
clutch SOLD
Old 07-09-2016, 07:54 PM   #4
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Does the headers have the collectors included?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-10-2016, 02:06 PM   #5
whateverpratt
Are these what you mean?
Old 07-10-2016, 03:42 PM   #6
jonesky2
jonesky2's Avatar
ncut unmolested harness $150
The DBW pedal, harness, and controller $50
ECM/PCM computer $75
I would like all of this. Would you do a package deal?
jonesky2 is offline   Reply With Quote
Old 07-11-2016, 02:34 PM   #7
whateverpratt
Not cutting any deals yet, but check back next week, and I'll let you have it for $275 + shipping. I'm hoping someone just buys the whole setup.
Old 07-11-2016, 02:37 PM   #8
jonesky2
jonesky2's Avatar
It's okay I don't need a deal, but I do need all of that, so I will still take them if your willing to separate.
Old 07-11-2016, 02:38 PM   #9
jonesky2
jonesky2's Avatar
I will check back next week lol sorry about that
Old 07-11-2016, 04:31 PM   #10
chuychevy82lwb
What year truck was thos going in in looking for some headers i have a set or truck manis on mine but there at a weird angle and dont want to get turned down when i take it to the exhaust shop
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 07-11-2016, 06:54 PM   #11
whateverpratt
I was planning on using them on a '63, and I think they would have fit. They really do "hug" the block as you can see in the pics.
Old 07-12-2016, 12:51 AM   #12
chuychevy82lwb
Thumbs up Re: 5.3 complete takeout
Let me crawl under my truck tomorrow after work to compare the pics u posted and see if it will fit if they do ill be more then happy to take them off ur hands
Old 07-16-2016, 11:44 PM   #13
teamadams
teamadams's Avatar
I will take engine please pm me info I can pick up locally thank you
teamadams is offline   Reply With Quote
Old 07-16-2016, 11:53 PM   #14
teamadams
teamadams's Avatar
does it come as pictured minus clutch flywheel and headers?
Old 07-17-2016, 12:04 AM   #15
chuychevy82lwb
I think there going to be too tight for my application bud that starter looks awfully close to the collectors sorry tp disapoint
Old 07-17-2016, 10:12 AM   #16
whateverpratt
No problem Chuy
team adams,
Correct, engine is $500 as pictured minus the headers clutch and flywheel
Old 07-17-2016, 03:58 PM   #17
whateverpratt
Engine sold
Old 07-19-2016, 02:20 PM   #18
whateverpratt
This is all I have left currently
original motor mounts $25
generic inline fuel pump (same as walbro 255) $60
Old 07-25-2016, 03:03 AM   #19
solidaxel
solidaxel's Avatar
Do you have the clutch and flywheel?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-25-2016, 09:20 AM   #20
whateverpratt
Already sold the clutch and flywheel. Sold the radiator and fans as well.
Old 07-31-2016, 07:52 AM   #21
elektro21
Possible to get a couple pics of the motor mounts? I might have a use for them. Thanks!
Engine only SOLD
Coils SOLD
shorty hugger headers (center dump) $100
AC compressor SOLD
original motor mounts $10
gen 3 to gen 1 motor mount adapters from advance adapters $50
radiator and fans $50
stock airbox $15
fusebox SOLD
AN fittings and connections $75
high pressure fuel line $25
flywheel $75
clutch $75
elektro21 is offline   Reply With Quote
Old 07-31-2016, 10:01 AM   #22
whateverpratt
Oh man, I haven't updated this in a while. I'm down to three parts left. Here's a link to the CL ad for the mounts that I still have.
http://beaumont.craigslist.org/pts/5690627195.html
Old 07-31-2016, 11:29 AM   #23
solidaxel
solidaxel's Avatar
You mean there is a market for these!
LS 3 4L70E
Old 07-31-2016, 02:22 PM   #24
whateverpratt
Probably not, I still have those and the stock truck manifolds, but you never know. Sometimes people come out of the woodwork and buy random stuff from you.
Old 07-31-2016, 05:47 PM   #25
elektro21
Actually, I think I can use them..PM sent
