Old 07-24-2016, 05:31 PM   #1
thedudeabides86
Active Member
thedudeabides86's Avatar
HEI Distributors
Hey everybody. I've got a '72 Chevy pickup with a 350 and points style distributor in it. If I want to convert it over to an HEI distributor, what do I need to do and what's the best brand to go with? I've got no experience with installing an HEI and it seems like I need to wire it into the battery? Any help would be greatly appreciated. Thanks!!
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 07-24-2016, 05:37 PM   #2
Dave in Ozark
Re: HEI Distributors
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
Dave in Ozark is offline   Reply With Quote
Old 07-24-2016, 06:23 PM   #3
dmjlambert
dmjlambert's Avatar
The electrical part: http://67-72chevytrucks.com/vboard/s...d.php?t=708975
dmjlambert is offline   Reply With Quote
Old 07-24-2016, 06:24 PM   #4
truckster
truckster's Avatar
I'm putting a Skip White distributor in mine:
http://www.skipwhiteperformance.com/...px?Item=6500-R
Instructions are on the web page as well.
truckster is offline   Reply With Quote
Old 07-24-2016, 06:30 PM   #5
davepl
davepl's Avatar
Go GM if you can. Avoid no-name Chinese units... I'd take a well used GM HEI over a no-name unit any day. I've heard good things about Skip White, but no personal experience.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-24-2016, 07:02 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x2. Many years ago I picked up a used 1980-something GM HEI and it's still going strong.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-24-2016, 07:30 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
If you go with a cheap Distrib, Skip White or others, carry a spare module with you. Don't ask . Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 07-24-2016, 08:34 PM   #8
Boog
laying low
Boog's Avatar
The HEI conversion is one of the best changes you can make to your chevy. You have many options. Grab one from the junk yard and take your chances or rebuild it or buy a new one complete from someone like O'Reillys for $125 or so with warranty or spend more on one from Accel, Taylor or others. You can find Skip White distributors new for around $50. Yeah they are pretty and I believe imported but for something driven occasionally they should be ok.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-24-2016, 09:24 PM   #9
GR8-68
GR8-68's Avatar
Am I reading that right ? 39.50 for a distributor ?
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-24-2016, 09:58 PM   #10
dmjlambert
dmjlambert's Avatar
What is the deal with those conversion modules that you install in the old points distributor to convert it to electronic? Are they a good idea? Do they need the resistor wire replaced just like HEI? I may have considered one if a friend didn't give me an HEI out of a later model Chevy.
Old 07-24-2016, 10:16 PM   #11
Mike C
Mike C's Avatar
Either the Pertronix Ignitor (or Ignitor II) or Mallory Unilite conversion work great. But harder to replace when they break.
For my money, I'm all about the cheap Chinese distributor and sourcing some parts as spares. A coil and a module.
The MSD Streetfire is probably a little better. They say it has same melonized gear as their other distributors. Just bought one myself for hydraulic roller compatibility. $160. But I'd have no problem running the cheap Chinese distributor.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-24-2016, 10:37 PM   #12
truckster
truckster's Avatar
Yep. And I had a technical question and they responded to my email within a dew hours - on a Saturday.
Old 07-24-2016, 10:38 PM   #13
Wrenchbender Ret
The Petronics is good if you have clearance problems with the big GM HEI or want the original look, but you can't beat the OEM HEI for performance & reliability.
Wrenchbender Ret is offline   Reply With Quote
Old 07-26-2016, 11:23 AM   #14
jeffahart
jeffahart's Avatar
I bought a Skip White about three years ago(it was called the "Ready to Run"). I have a tired 350. The simple HEI is a good upgrade. Spend your money on wires! Wires are important! All things equal, and especially for a stock type engine, you can use the cheaper distributors and be fine. I'm of the opinion that the basic swap out HEI distributors have reached appliance status. Again all things equal, they are a straight plug and play and you will burn the fuel.
Also, I should have mentioned, the "Ready to Run" is designed to run with an external coil. This distributor is designed to look like an original and resolves any firewall clearance issues. Just google Skip White ready to run and you can see it.
White K20
jeffahart is offline   Reply With Quote
Old 07-26-2016, 01:05 PM   #15
StoningtonQB
StoningtonQB's Avatar
I just converted to a GM HEI distributor a month or two ago.
Just to touch on a few things not mentioned already in the previous posts...
1) The part number for that spade terminal - NAPA 725145
2) Unwrap your harness from the PASSENGER SIDE FIRST!
3) Add your 12 gauge wire to the harness as you remove that resistor wire and re-tape the harness to MAKE IT CLEAN.
4) The distributor's firing order should match what you had on the points unit. Don't rely on Google search results, because cylinder #1 will be where it was before where you took out the old one.
5) I got a Summit Racing Ready to Run Blueprinted HEI distributor and it works great.
6) Use black RTV on the firewall plug where you replaced the old wire for that OE look.
7) Stick with vacuum advance
8) Ignition wires use 1975-1982 Corvette or better yet MAKE YOUR OWN!!!
StoningtonQB is offline   Reply With Quote
Old 07-26-2016, 02:19 PM   #16
CastIron
CastIron's Avatar
I installed a Streetfire HEI distributor on my pickup last year when I put a goodwrench 350 in. I haven't driven a huge amount of miles, but I haven't had any problems yet. It was a big improvement over points. My old points distributor had the timing moving around at idle when I checked the timing. This one is nice and steady with seems to start up faster. I just removed the resistor wire from the harness and replaced it with a 12 gauge wire with the proper connector. It's an easy project.
I installed an Accel blueprinted HEI on my Chevelle about 20 years ago. It's still working perfectly.
CastIron is offline   Reply With Quote
Old 07-26-2016, 02:33 PM   #17
jjzepplin
jjzepplin's Avatar
I put an Accel Blueprint In my Chevelle and followed the "curve" instructions. You will be pleasantly surprised with the results far outweighing the cost. It's like installing a new brain in your engine.
I then started doing this to customers cars. Oh my were they surprised as well.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-26-2016, 03:01 PM   #18
slikside
slikside's Avatar
That's the same dizzy I put in my stock '72 350. I bought it several years ago for about $75, but it came with a full set of the 90*, 8.8mm spiral bound Accel wires. Bought the crimper too. Custom fit the length to your appclication (plug end came finished, just cut to length at distributor end).
But I only recently installed it. I probably have less than a 1,000 miles on it, but no problems whatsoever.
The biggest difference I noticed was idle smoothness. The points/distributor I was replaced was probably fried/sloppy. Now, the timing is much more stable, and my hood is not bouncing/oil-canning at idle. Seems to fire up a bit quicker as well.
Time will tell on the durability, but so far, all good.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 07-26-2016, 03:58 PM   #19
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Don't forget to regap the plugs.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-27-2016, 10:06 PM   #20
Barnfind46
Barnfind46's Avatar
I dropped a used gm HEI in mine and it hasn't missed a beat. Very dependable.
Barnfind46 is offline   Reply With Quote
Old 07-27-2016, 10:32 PM   #21
57larry
go to Pick A Part and get a HEI for $20-25
57larry is offline   Reply With Quote
Old 07-28-2016, 01:06 PM   #22
bw46
bw46's Avatar
I have installed 4 pertronix kits in a variety of vehicles (Cadillac, Chevy, and Buick). Of them, one failed in about a year and one was bad out of the box. the others worked great, several years in.
I have installed 3 HEI units from GM and I have never had a problem with any of them.
bw46 is offline   Reply With Quote
chevy c-20 long bed, hei
