Old 07-25-2016, 05:42 PM   #1
ubtripn
ubtripn's Avatar
Has anybody ever used a modern spare tire assembly on our trucks?
I found a wrecked new truck, the kind where you lower the spare tire with a rod and crank. I took the box with the cable and the rod and I am re-welding it in place so I can suck a spare tire up against the frame. I already have a hole in my step bumper by my license plate that lines up for the rod so it should work. Has anybody else ever done this and if so anything I should watch out for? Thx.
ubtripn is offline   Reply With Quote
Old 07-25-2016, 06:56 PM   #2
firedemon
Re: Has anybody ever used a modern spare tire assembly on our trucks?
I don't have one on my 67 but my ranger has one here in new York if you don't drop it and clean and lube it atleast once a year they rust solid and you have to cut them off
firedemon is offline   Reply With Quote
Old 07-25-2016, 07:29 PM   #3
In The Ten Ring
I love the idea of spare tires, as I have helped many a stranded motorist and I have seen even more cars abandoned due to a flat. I have had three flats in my life and I changed each one in under 10 minutes and was out of there.
My truck is a stepside with spare tire cut out and I have heard that these under bed mountings are a nightmare without regular maintenance, failing you at the worst moment. However, if this setup will fit, you should be able to fab something up to get it to work. I think it's a great idea, leaving the bed open for hauling. Just be sure to give it a hard core cleaning, say every few months. I assume everyone on here changes their own oil, I'd think a spare tire cleaning could be added to the oil change routine.
In The Ten Ring is offline   Reply With Quote
Old 07-26-2016, 01:38 PM   #4
ubtripn
ubtripn's Avatar
Will do. I like it much better than the swing arm set up, just lower the tire and there it is. I did have to fab to cross members for the tire to rest evenly against but no biggie. My son took welding so I gave it to him to experiment with, he got er done. I will indeed lube it regularly. Thanks.
Old 07-26-2016, 01:56 PM   #5
In The Ten Ring
That's great man, I'm glad to read it. I'm a big fan of anyone that changes their own tires. These days we are much too dependent on AAA. *I have a friend who waited 45 minutes for a tow truck to come change his tire. SMH!
Welding is a great skill to have, I am glad your son knows it and that you have a son that helps his dad!
Old 07-26-2016, 02:04 PM   #6
CastIron
CastIron's Avatar
I know of a certain car manufacturer that used a product called Noxodul 300 to prevent the spare tire carrier cable from rusting. It's a black liquid that can be sprayed or wiped on and doesn't really dry, but gets more like wax. I imagine that would work well on a GM truck too.
http://www.noxudolusa.com/product/noxudol-300-aerosol/
CastIron is offline   Reply With Quote
Old 07-26-2016, 02:10 PM   #7
truckster
truckster's Avatar
My motorhome has a 97 Ford chassis and it has a cable hoist for the spare. I doubt it had ever been dropped before I bought it four years ago, but I haven't had any problem with it. It seems like it was made to handle the road and the weather.
truckster is offline   Reply With Quote
Old 07-26-2016, 02:24 PM   #8
TwoFiftyShifter
I got my 97 F150 from my grandfather. He bought it new. In 2014 I decided to drop the spare down. It came down like a dream. He had never touched it before.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 07-26-2016, 08:52 PM   #9
Overdriven
If the spare tire unit uses a cable it's more likely to remain free without much maintenance, if the cable is plastic coated then you're really golden. The older ones that used a chain are the ones that seize up bad after they get wet a few times let alone smell road salt.
Overdriven is offline   Reply With Quote
Old 07-26-2016, 10:01 PM   #10
MusicMan70
MusicMan70's Avatar
This unit came out of a late 80"' Toyota PU. I'd heard "story's" about the GM cable type snapping(?)
It uses a keyed rod to lower and lift and I put it in my Suburban.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-27-2016, 05:03 PM   #11
ubtripn
ubtripn's Avatar
Wow-perfect fit.
Yeah I am very lucky to have a son who is in to building not buying as he puts it. =)
Old 07-27-2016, 06:25 PM   #12
firefighterchevy
firefighterchevy's Avatar
Talking Re: Has anybody ever used a modern spare tire assembly on our trucks?
I used one under my 69 C10. It came from an 88-98 Chevy pickup, so it is the cable style. All I added was a piece of angle iron between the frame rails and used the existing cross brace. I drilled two holes for the bolts to pass through and one on each end of the angle iron to the frame.
I have noticed that some of the "hooks" on these that go through the wheel are of different design. I don't remember what year I removed the carrier from, bit I ended up putting an extension on the hook, since the hub hole on my stock steel wheel was bigger than the OEM hook.
I have heard of the cable breaking and the tire falling out from under the pickup as well. I experienced this myself on my 92 Chevy K1500, however, I feel it may have been a little self induced. I don't suggest cutting into a ditch at near highway speeds to go fox hunting in the dark of night, especially when you forget there's a large dip in the bottom to play Fall Guy from
My friends describe my house as the small town used Chevy Pickup dealership.
firefighterchevy is offline   Reply With Quote
Old 07-27-2016, 08:32 PM   #13
In The Ten Ring
Did he live where it snows four months out of the year and the roads are coated in salt?
Old 07-28-2016, 02:57 PM   #14
ubtripn
ubtripn's Avatar
Lol. I will remember that.
