07-27-2016, 08:30 PM | #1 |
What period correct tow hooks will fit a 1972 1/2 ton 2wd?
Title says it all!
I think front tow hooks look pretty cool but my truck is a 1972 two wheel drive. What years of tow hooks will bolt up, if any? |
07-27-2016, 10:18 PM | #2 |
Born Psycho
Re: What period correct tow hooks will fit a 1972 1/2 ton 2wd?
if your truck frame is punched for tow hooks the hooks of early 90s trucks will bolt up with only slight modification (the stock frame holes are very close to the hook hole spacing) and are cheap too, pick-n-pull is full of them. they aren't near as big and beefy as the OEM hooks but will pull anything you need.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
07-28-2016, 01:10 AM | #3 |
My frame probably isn't punched for hooks of any kind as it was just a base model bought off a lot and not ordered other than by the lot owner.
I guess I'll hold off on mounting hooks for now. Thanks though. |
