Old 07-29-2016, 10:00 AM   #1
craigg1
Radiator Rubber Mounts
I need to order some radiator rubber mounts. Are there just 2 on the bottom of the radiator or are there also 2 that are suppose to be on the top as well....and if so, are the top and bottom identical? Thanks.
67 C10 SWB Chevy
craigg1 is offline   Reply With Quote
Old 07-29-2016, 11:38 AM   #2
Ironhorse
Ironhorse's Avatar
Re: Radiator Rubber Mounts
The rubber mounts or cushions are identical for both the top and bottom supports. Be sure you know which you need, the same cushions are used for the 2 and the 3 row radiators while the larger 4 row radiator uses a bigger cushion. Hope that helps.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-29-2016, 11:49 AM   #3
craigg1
Great, thanks for the help.
67 C10 SWB Chevy
