L31 crate- what kinda cam?
How big of a cam can a person put into a L31 350 SBC crate motor can handle without major mods?
Lunati - Vuddo |
Senior Car Nut
![]() Join Date: Jan 2008
Re: L31 crate- what kinda cam?
what I've always seen is .470 lift is where you might want to start checking retainer and seal clearances. I've also seen .480. for reference, the cam used in chevy's Vortec-headed RamJet motor gives .481 lift with the 1.6 ratio rockers that engine uses.
that cam is the one I used in my L31, but with the 1.5 rockers (.451 lift)
Larry |
#3 | |
![]() Quote:
I have looked at some of the Lunati Voddo Cams and others but it appears they all have around .500 lift or more ![]() |
#4 | |
Posted via Mobile Device |
Call the cam company of your choice and have what you want made. a 230/230 (@.050) cam with .460/.460 lift won't be a problem- nor any other...
Senior Car Nut
I did a lot of assuming when I read your post. I assumed this was a new, "in-the-crate" engine and I should have asked what you meant by "major mods". I drew the line on my new crate at simply swapping the cam.
Willi2Ds has a good point about the studs if your definition of "major mods" is different than mine, there is a simple "mod" you can make to the spring retainers to increase lift (see the last part of this post: http://www.nastyz28.com/forum/showpo...35&postcount=2 ) and, although I didn't check it out, here is a cam someone suggested a couple of years ago: http://67-72chevytrucks.com/vboard/s...54&postcount=2 **you might want to ask the moderator to move this thread to the Engine and Drivetrain section, you may pick up a lot more replies
Larry |
Java Mechanic
Moving thread to correct section.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Brian tooley. No questions asked.
![]() ![]() Join Date: Oct 2014
I just installed one of these in my truck, http://www.lunatipower.com/Product.aspx?id=4578&gid=289 FWIW
60-66 Nut
![]() ![]() Join Date: Mar 2007
Just swap in a Ram Jet 350/HT 383 cam with a set of 1.6 rockers. Check the pushrod clearance going thru the head with the 1.6 rockers. Even if you have to stay with 1.5 rockers, that will make a strong running engine. Both Comp and Lunati make roller cams with less than .500 lift.
I ended up putting a xe268 cam in my 357. No other valvetrain mods. As long as you stay near .490 lift and don't go over on factory heads to will be ok
#12 | |
I can say I am happy with the response and power I get from my engine with this cam. When I chose my cam I asked the machinist to make sure there was enough clearance to the seals and he clearance them enough to cover a cam with 0.500 lift in case I decide to go a little bigger in the future. Bottom line is check the clearance, don't assume you have enough to run a 0.480/0.490 lift cam. There's enough articles on the vortec heads to suggest that they only have enough clearance for about 0.470 lift.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
#13 | |
Thanks again |
#14 |
Senior Car Nut
I don't know if this is going to work (I have to click on the "options" buttons on the upper right and tell it to download). taken with my phone, sound quality is terrible. this is the ramjet cam with stock L31 1.5 rockers:
https://photos.google.com/share/AF1Q...4xOXhINlFhYVNn
Larry |
#15 |
That sounds pretty healthy! 👍
#16 |
Senior Car Nut
Thanks frankintruck, it might be the 109 degree lobe separation
or maybe the Sweet Thunder mufflers ![]() I do wish the sound was better from the cell phone as far as the hp possibilities go, compare the components of the L31 with the RamJet cam to say, the GM 350 HO which is rated at 333 hp with a dual plane manifold and 600 cfm Holley. both are 350 cu in 1 piece rear main seal blocks with nodular iron cranks powdered metal rods and cast dished pistons the L31 is rated at 9.4:1 compression ratio, the HO at 9.1:1 both have vortec heads with regular vortec 1.5 ratio rockers the only real difference I see is the cam the HO is flat tappet hydraulic with .435 in. intake lift and .460 in exhaust lift with duration at .050 in. for intake is 212 and 222 for exhaust with a 112.5 lobe centerline. (I'm assuming they are referring to LSA) the lift is similar to the Ramjet (.431/.451) but because the RamJet is roller, you really can't draw a conclusion about the duration values since the roller lobe profile should/could be more aggressive. lobe separation angle on the RamJet is 109 which is considered "tight" from what I understand. on two cams with otherwise identical specs, the one with the tighter LSA would have more overlap. another comparison, FWIW, would be the GM 383 (9.1:1 compression ratio, dished pistons) which also has vortec heads and the Ramjet cam. rated at 323 hp so, who knows? 300+?
Larry |
#17 | |
thanks Larry! I''m pretty sure that is the route I will go. ( I may go with 1.6 roller rockers also) Thanks for the help! |
#18 |
Just thought I would update ya'll
I ordered my L31R last night from Jegs. Should be here Friday. Now need to get cam. |
