08-07-2016, 05:42 PM | #1 |
Coil springs & bags problems?
a guy has a 1/2 ton short bed for sale with 2 inch dropped coil springs in the front and air bags in the rear. any problems with this set up? thanks, Larry
08-07-2016, 07:58 PM | #2 |
Diggin The SquareLife
Re: Coil springs & bags problems?
depends on how good of install of the bags
08-07-2016, 09:01 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Thats kinda my set up but I have 2.5 in drop spindles as well.
Look how the bags are mounted, in place of rear coils then fine. How are the bags plumbed, just air line and schrader valve? Compressor and tank? Get some pix or go look at it, take another set of eyes as well.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-07-2016, 09:42 PM | #4 |
thank you for the replies. no tank or compressor. looks like the bags are mounted well. bags tee into a single line
08-08-2016, 02:35 AM | #5 |
If they are bags over leafs those are more used to level the truck kinda like air shocks use to be.
08-08-2016, 01:13 PM | #6 |
I had mine t'd off for a time but recently split them.
Either way worked for me.
08-09-2016, 09:09 AM | #7 |
eventually, you will want to separate the lines for individual control of each bag, and add an on board compressor, gauges and valves. Our shop truck, the J.T., has coil spring front and bags in the rear, and it works great.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
