08-29-2016, 12:54 PM | #1 |
My 1985 C10 Prostreet Project!!!
08-29-2016, 05:28 PM | #2 |
Re: My 1985 C10 Prostreet Project!!!
Nice!!!
08-29-2016, 06:25 PM | #3 |
Camaro Club
I like it. I didnt realize you could tub these trucks with a stock backhalf by just moving the springs inside the frame rails.
09-02-2016, 12:47 PM | #4 |
Is it really as simple as moving the leaf spring mounts inboard?
Very cool truck! What engine/trans will you be running?
My LS/T56 C10 build...http://ls1tech.com/forums/conversion...t56-build.html |
09-06-2016, 12:17 PM | #5 |
by moving the springs inboard and narrowing your rearend who can go much wider of rim and tire and u can cut the inner wheel housing and wider them. im running a 15x14 with a MT 29-18-15 tire.
09-09-2016, 04:37 PM | #6 |
Frame rails should be boxed in first.
06-26-2017, 12:29 PM | #7 |
