Old 10-17-2016, 10:40 PM   #1
IdahoMan
Drilling extra holes in frame
Hello,
Any dangers, rules, or pointers I should keep in mind when drilling holes into any part of the frame? I don't want to weaken it or harm the structual intergrity in any way. I don't like the idea of drilling into it at all, but I need to place some clamps in in order to run some cable.
Now under the cab area above the spining shaft I made some "L" shaped sheetmetal pieces and used 3M attachment tape to attach them. I drilled into the pieces and not the cab, but I need to run heavy cabling along the inside of the left frame rail.
Thank you.
Sincerely,
IM
IdahoMan is offline   Reply With Quote
Old 10-18-2016, 12:05 AM   #2
geezer#99
geezer#99's Avatar
Re: Drilling extra holes in frame
Drill away!
You won't hurt anything.
Back in the early sixties there were Pontiac's with a multitude of holes in the frame. Purposefully done to shave off weight for racing.
They called them 'Swiss Cheese' Pontiac's!!
Check out this frame.
http://www.onallcylinders.com/2015/0...eese-catalina/
Old 10-18-2016, 02:24 AM   #3
Matt Man
Matt Man's Avatar
I wouldn't drill any holes near where these frames crack such as steering box and shock mounts.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 10-18-2016, 02:53 AM   #4
andrewmp6
Depends the size hole and where your gonna put it.
andrewmp6 is offline   Reply With Quote
Old 10-18-2016, 03:59 AM   #5
Nick_R_23
Nick_R_23's Avatar
Heard that from a few ladies before
Old 10-18-2016, 09:14 PM   #6
nekkidhillbilly
dreams are not real mind you
nekkidhillbilly is offline   Reply With Quote
danger, drill, frame, safety
