10-25-2016, 06:50 PM | #1 |
4l60E Range Connector
I have a 2003 4L60E and the harness I received has this connector.
Is there a different switch I can place on my transmission 0r do I need a different harness connector?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
10-25-2016, 06:55 PM | #2 |
Re: 4l60E Range Connector
the gray one? my 03 harness doesnt have that one either
5.3 4l60 2wd. (mine) wonder if its for 4wd
1967custom |
10-25-2016, 08:38 PM | #3 |
Your harness is set-up for a 2004 & newer Range Switch, It will bolt right up to your 2003 4L60E.
10-26-2016, 09:56 AM | #4 | |
Is there any other changes in a 03 wiring harness for the transmission or is a 04 the same? The other harness I have do not even have a connection,connector, for the transmission at that location
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 10-26-2016 at 10:02 AM. |
10-26-2016, 11:24 AM | #5 |
My aftermarket harness didn't even come with a range connecter, not sure it is even required.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-28-2016, 11:35 PM | #6 |
I found this one, will it work?
ACDELCO D2257C {#24221125} GM
10-29-2016, 01:03 PM | #7 |
Yes, that's the one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-29-2016, 03:13 PM | #8 |
Thanks Folks !!
