![]() Join Date: Jul 2009
Jeep wrangler EFI complete tank, skidplate and brackets.
SOLD
I have a complete Jeep Wrangler EFI fuel tank equipped with the proper fuel sending unit with new A/C Delco EP381 fuel pump for an LSX swap. I also have the proper Jeep skidplate and straps to help protect it from damage out back. $250 plus shipping [Doesn't include any related sales fees (i.e. Paypal)]. Forgot to mention... everything is brand new and unused. And this is a 15 gallon tank, so it's shallow enough to maintain excellent ground clearance and narrow enough to be able to route fill lines etc without issue. Last edited by nlped; 12-04-2016 at 09:51 AM. Reason: Sold |
one set closer
Re: Jeep wrangler EFI complete tank, skidplate and brackets.
Hey nlped do u have the part number for the sending unit? Wish this was for sale 2 week ago.
I'll have to see if I can find it. It's the 4-cyl Jeep Wrangler sending unit minus the Jeep pump. I then added the AC Delco pump.
one set closer
OK thanks
I didn't mention it in the original post, but everything included in the sale is brand new.
New pictures that show the skidplate and brackets as well as the sending unit.
![]() Join Date: Oct 2007
How many gallons is that?
Thx...Alan |
#13 |
#16 |
What are the dimensions of the tank?
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#17 |
I will measure it and report back this evening when I get home from work.
#18 |
I totally blanked on getting measurements. I'll do it as soon as I get home this evening.
#19 |
One other question, what size is the filler neck hole?
#20 |
![]() Join Date: Jun 2009
I know you say this is for an lsx swap but could it be made to use on standard sbc hookup ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#21 |
The tank measurements are 25.5" W x 18.75" L x 11.5" T. The skidplate is the same width but adds an additional 3" to the length (front to back measurement). The skidplate provides the mounting holes btw. The filler neck is 1" with a .75" 'vent' neck above it. I'm sure it could be used for that, but either the pump would need to be replaced with a low pressure pump or some sort of regulator/return setup to meter fuel pressure. (This is assuming you're talking about a carb'ed sbc) |
