testing lq4: no oil at rockers
I have a 6.0 lq4 that i bought off craigslist a while back. I swapped the cam, replaced heads, new springs, oil pump, timing chain, push rods (7.4" TSP)
the bottom end is still stock and i inspected it for any damage or wear. looked good. during final assembly i put 5 its into the motor through the top end and then rolled the motor over to see if i got any oil out of the push rods and into the rocker. NONE that i can see. What could be causing this issue? I just used the starter without plugs or coil packs while on the engine stand in order to check. |
Re: testing lq4: no oil at rockers
Did you pack the oil pump with assembly lube or that white grease ?
I just ran across this video the other day and will probably use this technique in the future. https://m.youtube.com/watch?v=539ClWWJMl8 |
Another thing to check is the o-ring on the pick-up tube. If it's the wrong one or damaged, the pump will pull air around it and not pull oil.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
How long did you crank it over for ? My engine took 3-4 minutes to get oil pressure up to the rockers after draining all the oil and changing to the ctsv oil pan.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
That's what I was wondering. It's hard to do just by cranking. You'd probably burn the starter out first.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
I always did the cranking thing also and did not seem to get the results I would have liked to . I got to looking into it and gm recommends priming from the front lower plug on the drivers side . I got me a cheep 1 gal pump up garden sprayer and got an extra plug and drilled it for a barb fitting . Screwed it in and added oil to the sprayer and pumped away . After a few minutes I had oil coming out of the push rods . I now prefer this over the starter method . I just cant help from thinking the starter is taking a beating cranking on it that long .
![]() Join Date: Jan 2009
Totally agree with homemade87. After watching a few people crank their engine for several minutes with no oil up top, I used the pump garden sprayer and had oil in the rockers with 3qts and just a couple minutes.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
Thanks for all the responses guys. Im going to do the bug sprayer method. I ordered a few fittings to do it this week. what i'll probably do is drain the oil pan, fill the new filter and then pump 5 qts into it at the front driver side plug.
oh and I needed to change the starter anyway the previous owner broke one of the terminals off while pulling it out of the vehicle. I've got one waiting lol. |
O-ring isn't pinched I had heard of this problem before and made sure not to. I used the blue o-ring that came with my new oil pump.
I've never managed to get an LS motor to self-prime just from cranking. Only luck I've ever had is with a pressure-fed oiler.
