Old 11-26-2016, 08:53 AM   #1
pvienneau
pvienneau's Avatar
Rear Pinion Bearing Fit Help
Purchased a rear pinion and gear for 49 1/2 ton torque tube. The rear bearing does not fit. Seems way to tight to fit in tube. If I hammer it in it will not be easily removed for adjusting whip. I want to find out if it is the tube or the bearing. Does anyone have a torque tube that we can test fit to see if its my tube or the bearing? I will send the bearing for test fit if you have one.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
