Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-29-2016, 05:49 PM   #1
tj2tens
Chevy 350 with odd distributor
This is an odd issue and having trouble figuring it out. I have a used Chevy 350 crate engine (block #10063606) and the distributor that came with it is model # 1111364. It has a weird bulb coming out of it and a electrical sensor of some kind. It has points, that's where I have a problem. I want to convert this over to electronic ignition.
However, at the end of the distributor it has a rectangle/squarish female slot with the corresponding male part at then end of the oil pump shaft. When trying to find a distributor to replace it no one has that type of connection.
With all the research I've done, some suggest the distributor is out of an early 70's bigger Chevy truck. And maybe the electronic sensor might be an over rev limiter.
tj2tens is offline   Reply With Quote
Old 11-29-2016, 10:36 PM   #2
sweetk30
sweetk30's Avatar
Re: Chevy 350 with odd distributor
what about petronix conversion kit and reuse your dist and forget about whole new unit.
http://www.pertronix.com/
can buy them most any parts places or speed shops .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-30-2016, 05:20 AM   #3
Bob B.
Looks like it fits '71-'72 350's in C-50/5500 medium duty trucks. The switch and fittings are for a governor. Can't use a regular small block distributor with the oil pump shaft you have, maybe the oil pump is different too? I am not sure. A Pertronix is a great idea if the distributor shaft is still tight.
There is a new one on Ebay right now:
http://www.ebay.com/itm/like/2708511...&ul_noapp=true
No connection to seller.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
