Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 10-12-2003, 05:09 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Electrolosis eating heater core?
My buddy has a 94 burb and the heater cores just rot out of it. Both front and rear went out, so he bought a new one and it lasted 3 months. He took it back and they gave him a new one, but the guy told him an electrical short was eating the aluminum cores....
Anyone ever heard of such a thing? The battery has one of those battery buddy things that disconects the battery if there is any batery drain and it isn't going off, so I am doubting this story.
I'm thinking his water has something in it that is caustic. Can you get Non-aluminum heater cores? any advice?
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 10-12-2003, 06:19 PM   #2
Scrub
Scrub's Avatar
I am moving this to the discussion board. Oops
Scrub
Old 10-12-2003, 08:21 PM   #3
oldsgmc
Same thing happened to me. With aluminum radiators and heater cores combined with so much electronics you get electolisis. What I ended up doing is running purified or dionized water and so far no problems. You might have him check for grounding problems to the engine.
oldsgmc is offline   Reply With Quote
Old 10-14-2003, 10:49 PM   #4
ThreeQuarter
ThreeQuarter's Avatar
Read this thread:
http://67-72chevytrucks.com/vboard/s...threadid=42231
BTW, I am still running on the same heater core since I changed to pink/orange antifreeze (Dex-cool). And I didn't simply drain the system and fill with Dex-cool, I had a radiator shop flush the green stuff out first. And of course I used distilled water, too. Good luck!
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
