01-06-2017, 11:04 PM | #1 |
Upper link bar angle
Hey first time posting on here ...im doing air ride on my square and im currently working on my tri 4 link..now i have the bottom bars tacked up and am ready to tack the uppers up but im a little unsure of exactly how they should be ...i have a piece of 6x2 tubing btwn the rails as a xmember for the upper links and I was planning on welding the upper bar brackets to it but after notching for the driveshaft i wouldnt be able to triangulate them much, they look almost straight....question i have is what angle should the top bars be on...someone told me level but i know ive seen them on angle.....ps how do i post a pic to go with this post
01-06-2017, 11:56 PM | #2 |
Post Whore
Re: Upper link bar angle
Level will work for street driving. If yourmputting serious power to the ground you'd want the bottom bar level and the top bar angled down. In the front ..so if they continued on an imaginary line the lines would intersect about 3 ft ahead of the front bumper..search for ron sutton suspension..hes a master of suspension setup..he has a tutorial on proper setups
01-07-2017, 12:55 AM | #3 | |
01-07-2017, 12:57 AM | #4 |
01-07-2017, 01:02 AM | #5 |
The lower bar should be horizontal at ride height.
Upper bar horizontal will be fine (as mentioned above). I have seen some tutorials suggest angling the upper bars so that their centerline intersects with the lower arm centerline at about the front bumper of the vehicle. Angling steeper increases anti-squat (usually good for launch, not always good for cornering). DO NOT have the upper bars angle ~up~, such that the centerlines intersect ~behind~ the truck. Don't do that.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
01-07-2017, 01:53 AM | #6 |
Post Whore
5150..different devices vari on how to do pics...on mine if I scroll down from where I reply to a post there's a (manage attachments) box..I click that and it gives me the option to add 5 pics..clicking on those takes me to my photo gallery where I chose my pic..then hit download and its done..what device are you using?
01-07-2017, 02:11 AM | #7 |
Post Whore
After rereading you question I think we may not have understood what you asked...I think the angle your referring to is the top bar of the triangulated 4 link..the angles of the the top bars if you looked straight down at it from above..I'm thinking you mean you can't bring the front of the top bars together because if your driveshaft loop...is this right? You may have to do a reverse triangulation..or go with a panhard bar or watts link...but from a side view the bars should be level..
01-07-2017, 09:16 AM | #8 | |
01-07-2017, 09:19 AM | #9 |
Mongo iPhone
Posted via Mobile Device |
01-07-2017, 12:07 PM | #10 |
Post Whore
I don't know about a I-anything...I know people have difficulty with those
01-07-2017, 08:13 PM | #11 |
I found my instant center witch came out to 5 degrees. Should I tack them at 5 degrees or level?
01-07-2017, 08:25 PM | #12 |
Your instant center is a location. What location did you pick? If it's around the front bumper, and the upper arms end up at 5° down (at ride height), then tack it in. 5° seems a bit steep off the top of my head, but I certainly haven't done the measurements for the C10.
.... or did you use one of them 4-link calculators available online? If they say 5° and you're happy with the amount of anit-squat, giv'er. It may be worthwhile to make them adjustable - not a whole lot more work. This is on my Pontiac Firefly (Chevy Sprint) (notice the forward mounts):
01-07-2017, 08:57 PM | #13 |
01-07-2017, 09:14 PM | #14 |
What I did was put a string from the upper bar mount on the rear end and ran it to the fromt of my bumper where it intersected won the lower bar and I put a angle finder on the string and the angle was 5*... am I confused lol
01-07-2017, 09:35 PM | #15 |
Post Whore
That intersection point will be different depending on your wheelbase..thus changing that top bar angle..i agree with skinny,, if your happy with it then go with it..should be ok..but you can raise the front mount up to the point of being level and still be ok for just a street cruiser..adj front brackets like he used are great for fine tuning..the intersection point of the top and bottom bars is more critical in a higher hp truck..adj the angle of the bars moves the intersection point foward or back and thus affects the weight transfer of the truck under hard acceleration.
01-07-2017, 10:10 PM | #16 |
Consensus seems to be put em level. And it's a cruzer so level it is. Thanks for the help. I shoulda tried this forum months ago when I was told about it..
01-07-2017, 10:27 PM | #17 |
Another ? Is it ok to clock the axle bar bracket forward or should it be at 12o'clock? I'm trying to get the front bar bracket to be level with the xmember but when I clock it forward one of the axle brackets comes off the axle a little bit
01-07-2017, 10:49 PM | #18 |
Post Whore
It should be ok as long as both sides are the same..making sure the axle is centered side to side and square with the centerline of the frame measured with triangulated measurements..I'm assuming the u bolts are holding the axle in place where it cant move while you setup the 4 link..typically you would want the pivot points at the axle to be lined up vertically but I think you can cheat it a little
01-08-2017, 02:43 AM | #19 |
Garagely, sounds like you are on the right track. I approve. Keep going!
The Fiendish Firefly <<<<<<<< Here is my thread.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 01-08-2017 at 02:50 AM. |
01-08-2017, 09:45 AM | #20 |
Thanks will do
01-11-2017, 11:00 PM | #21 |
All tacked up... feeling pretty good about it. I'm a little anxious about cutting the tacks off the frame to the axle bc if I did something wrong my axle won't be squared in the frame anymore
01-12-2017, 01:45 PM | #22 |
It looks to me like you need to rotate the axle a little bit to bring your pinion angle down. I see that you have some adjustability in the links so maybe that will be enough. For what you are building I think you only need a couple of degrees there. My experience is with off road stuff so others know more than me here, but I thought I should open the conversation.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-12-2017, 05:59 PM | #23 |
I would match the output shaft angle, less 1° because you're using poly bushings. At ride height.
If the trans points 5° down, point the pinion 4° up. Make sure the arm brackets are such that you have adjustment either way, in case reality differs from theory (it often does).
01-12-2017, 10:17 PM | #24 |
I tried to match the pinion angles. I was told 3* is optimal. But all I could get out of my tranz is 8* if I jacked up the tranz any more it was putting a lot of stress on my motor mounts. So I made my axle 8* as well but I just articulated my axle up about 10 inches and put it back down and it seems to be ok but after I checked my axle pinion angle again it's more like 7* and when I cycled it up the pinion angle dropped to 0 at 10 inches high
01-12-2017, 10:24 PM | #25 |
Cycled 10 inches up
