Old 01-19-2017, 11:12 AM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
VSS with a TH350...
OK, I am putting in a LM7 into my truck, but I am using a TH350 for the trans since I had one sitting ready to go.
I have heard that I need to have a VSS signal that goes to the PCM to help avoid stalling the engine under hard breaking conditions. Since the TH350 has no provision for a VSS sensor, HOW DO I get that signal to the PCM?
OR - Do I really NEED that signal to the PCM?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-19-2017, 11:49 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: VSS with a TH350...
Yes you need one. You can use this: http://67-72chevytrucks.com/vboard/s...d.php?t=696560
Let me know.
Hart_Rod is offline   Reply With Quote
Old 01-19-2017, 02:13 PM   #3
aggie91
aggie91's Avatar
Thanks Rob. I really wanted to run the stock mechanical speedo too. Let me looking that and I will get back to you. Your part looks like a good deal if I skip the stock speedo.
Karl
The LST Challenge:
Old 01-19-2017, 03:24 PM   #4
Hart_Rod
Hart_Rod's Avatar
No worries. LMK.
Old 01-23-2017, 11:08 AM   #5
TooTall
I'm running mine without the VSS on a TH350. I turned off engine braking in the tune, so no worries with it.
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 01-24-2017, 11:15 AM   #6
aggie91
aggie91's Avatar
Thanks for the input. I have heard that I can do that, but just not sure what I want to do just yet.
Look like Dakota Digital has a 8k per mile pulse generator that is a pass thru that will let me keep my stock speedo. Seems to be cost effective at under $50.
Karl
The LST Challenge:
Old 01-25-2017, 11:54 AM   #7
MalibuSSwagon
jagsthatrun has this kit, pricey tho for what it is.
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
I believe the 8k pulse pass thru sender works as well. I am actually not running a VSS at this time, I don't have stalling issues but decel is not as smooth has it could be. But I am running an SM465 manual, not sure how well that will work with an automatic.
MalibuSSwagon is offline   Reply With Quote
Old 01-25-2017, 12:36 PM   #8
72MARIO
72MARIO's Avatar
I think that in the tune you can adjust the tune to accept 8000k . That dakota digital piece should work for you.
Who is programing your pcm ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-25-2017, 12:48 PM   #9
aggie91
aggie91's Avatar
I have spoken to the tuner, he can program the VSS to accept the 8k pulse signal. For this swap I am just going to have Brent at lt1swap.com do the vats delete and turn the codes off for the trans when I get it done.
Karl
The LST Challenge:
lm7, th350, vss
