Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 02-12-2017, 06:40 PM   #1
IronHorseman
Talking Joined The Darkside
Howdy you All!
Names, Forest, have finally joined a Chevy fourm, as I have now joined the Dark Side, still a tried and true Ford man on the inside but have to put that behind me as i am now behind the wheel of a 92 K3500 454 w/ 4L80E that will be the last truck i own.
I have quite a few questions regarding the plans I have for this rig with huge potential.
The plan for this is basically a lifetime bulletproofed tow rig/farm truck/ daily driver. The base is an extended cab longbed. i will be Solid Axle Swapping with a Dana 60 front and Rear, swapping to a built motor with between 400 tq and hp.
The issues ill be encountering will be the tbi and ecm that i hope to be able delete to run carbed but keep the almost new trans unless i need to replace to take the crate power, also tossing the idea of putting on a GearVendor over/underdrive
TL;DR - Tbi 2 Carb swap with 4L80E?? ECM delete?? HOW?? THANKS In Advance!
IronHorseman is offline   Reply With Quote
carb, ecm, tbi
