Old 10-16-2003, 05:59 AM   #1
LeRoy
Registered truck nut
LeRoy's Avatar
3spd. Overdrive F.S.
It works good, been converted to a floor shift, missing some of the gizmos. Doesn't have the linkage to shift into overdrive. The electrical thingy is still attached. OLD IRON gave me a brief rundown on the operation and it must be stuck in OD as he said it wouldn't go into gear unless it was. I agree as the shifter thingy is wire tied in position and 1st gear is alot higher then any other stick I've driven. As you can tell I know almost nothing about these other then they are kind of a rare tranny. I don't have the right speedo spud to so no speedo hookup at this time. $75 OBO
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 10-16-2003, 06:30 AM   #2
HOTFUN
HOTFUN's Avatar
Is it the Saginaw transmission or the BW trany? Or is the cast code on the side of the case R10 H1 or R10 Q1? I am interested if it is the Saginaw R10 Q1.
HF
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 10-16-2003, 06:34 AM   #3
LeRoy
LeRoy's Avatar
I have no idea. I'd have to check on that
Old 10-16-2003, 09:42 PM   #4
LeRoy
LeRoy's Avatar
ttt
Old 10-16-2003, 10:11 PM   #5
HOTFUN
HOTFUN's Avatar
Leroy
I am very interested, and a quick ID is does the shifter lever(s) cover plate have 4 bolts or seven holding the plate on? If it is 7 it is a saginaw and will have a Q1 or maybe an R1 code. Do you have the overdrive cable from the dash to the trany?
Mark
'72 GMC K2500 4x4
Old 10-17-2003, 11:51 PM   #6
LeRoy
LeRoy's Avatar
I'll check that out as soon as it quits raining. lol I don't have any cables or anything. I don't think this tranny came with this truck originally. Looks like they just locked it into OD and that's how it runs.
Old 10-19-2003, 11:31 PM   #7
LeRoy
LeRoy's Avatar
It has the 4 bolt cover so it's a BW tranny? What's BW stand for?
Old 10-20-2003, 01:23 AM   #8
fine69
fine69's Avatar
BorgWarner
fine69 is offline   Reply With Quote
Old 10-25-2003, 03:00 PM   #9
HOTFUN
HOTFUN's Avatar
Leroy
I am looking for the Saginaw 7 bolt cover style. Yours is a 55- 64 style Borg Warner. The Saginaw was used from 65 to 69.
Thanks for checking.
HF
'72 GMC K2500 4x4
Old 10-26-2003, 12:06 AM   #10
LeRoy
LeRoy's Avatar
No problem. What's so special about the Saginaw. Is it stronger then the Borg warner. Just wondering, for future reference. Still available if anyone needs it
Old 10-26-2003, 09:27 AM   #11
HOTFUN
HOTFUN's Avatar
Leroy
The later Saginaw has a fully synchroed first gear. They are not very common of the overdrives as this market was winding down by 1965 with the 3 speed automatics comming in. I have a rare Saginaw OD that came from a 69 Chevelle with a 307 but someone dropped and cracked the rear case and solenoid. I have looked everywhere for one for parts or a case without any luck.
Mark
'72 GMC K2500 4x4
Old 10-26-2003, 01:45 PM   #12
LeRoy
LeRoy's Avatar
Thanks for the info. I'll keep an eye out now that I know what I'm looking for.
Old 10-26-2003, 06:27 PM   #13
bad 71 chevy
bad 71 chevy's Avatar
Hear are some guy that have stuff for the 4 speed trans
http://www.5speeds.com/newm22.html
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
