Old 02-24-2017, 12:12 AM   #1
a1960apache
a1960apache's Avatar
Suspension solution for centering wheels in wheelwell?
Hello all, anyone have advice or a solution to getting the wheels centered in the wheelwells other than using Porterbuilt parts? You guys know what I am talking about. Anyone ever tried to reposition the wheel opening?
a1960apache is offline   Reply With Quote
Old 02-24-2017, 09:45 AM   #2
patrickk1
Re: Suspension solution for centering wheels in wheelwell?
Torch the Rivets on the trailing arm crossmember and shift it back the desired amount. If you have a c-notch or step notch, make sure the axle still fits into it. Shift panhard mount back depending on how far you shift the axle back. Or, Build/Buy yourself some new trailing arm crossmembers that are slightly longer.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 02-24-2017, 12:47 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I went the sheetmetal modification route. I sectioned and moved the wheel openings on the front fenders and bedside. I dropped the lip of the front fender down 2.5 inches. The bedside modification was mostly to widen the opening 3.5 inches forward to center and accommodate the 31" diameter tires.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-25-2017, 12:11 AM   #4
racecougar
racecougar's Avatar
Ditto. I moved the front of the opening forward 2" to center the wheel and accommodate a 33" tire.
(It sits lower than shown in the photo below)
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
