02-25-2017, 12:37 AM | #1 |
Body alignment issue
My cab and bed body lines are not matching up. After installing new cab bushing it sets a lot higher the the bed. Is there any spacers or mounts that go under the bed to even this out? Did I buy or install cab bushings wrong?? The bed was off the truck when purchased so kind of frustrated in pointers would be greatly appreciated
02-25-2017, 11:58 AM | #2 |
Re: Body alignment issue
How far off are they? Could just be your new mounts aren't worn as much, or could be the wrong ones. Beds also have rubber spacers between the bed frame and body frame, so that could be missing as well.
02-25-2017, 12:41 PM | #3 | |
Posted via Mobile Device |
02-25-2017, 01:16 PM | #4 |
To be honest I'm not sure if all of them have them or use them. Mine have about 1/4" rubber spacers.
02-25-2017, 01:16 PM | #5 |
It's Better With Nitro
This is after your torqued down the cab mount fasteners?
02-25-2017, 02:04 PM | #6 |
02-25-2017, 05:26 PM | #7 |
I torqued mine to 50 lbs.
02-25-2017, 09:42 PM | #8 |
Which is higher, the bed or cab. I had to shim my cab upto the bed, around an 1/8".
02-25-2017, 10:43 PM | #9 |
02-26-2017, 01:00 AM | #10 |
Yeah, there is no way, you should see the height difference by fenders sloping towards core support. I would double check it against some other body mounts.
02-26-2017, 02:30 AM | #11 |
Just in case, this is the diagram of the cab mounts, shapes, and order they are installed:
